Test of time - this "floor" may not last either...could go back up to .050 or could sink down again. Need a good few weeks of averages to find out where the real floor is. Honestly don't think it has one, it's too volatile and there's too much happening with the company. Seismic due in June and at any moment a joint venture could drop and be a game changer. Lock your shares in the bottom drawer.
Or sell them and but a jetski
Same same
Keep your eye on the market - this could be different being a capital raising, but 88E news has recently been released on the same day as the trading halt. Friday is just the latest they can release it.
No, but ASX companies don't usually make discoveries like this. It's characteristic of a speculative share where a lot of things happen in a short space of time, rather than a "business as usual" company, where a trading halt might only be called for a merger or buyout or acquisition.
Trading halts are usually called for the release of market sensitive information; the idea is to curb insider trading by ceasing trade as soon as the information is known, so that everyone finds out at the same time before it resumes trading again. Bluechips don't have much in the way of market sensitive information appearing on the regular, so all they do is disclose reports and changes in interest without trading halts. Speculative stocks like oil explorers can have a trading halt nearly every week (we did at one point) because there is so much information coming to fruition that can affect share price.
There are a shitload of happenings for 88E this year, so there will be plenty more trading halts. Sometimes it's a good thing, sometimes it's bad.
In all seriousness do companies on the ASX usually have this many trading halts? It's only been 2 in 2 months but is this a normal amount?
not unusual if there shit going down.
means they either kicking off or crashing.
I was about to buy in as it had dropped.
till they said they were announcing a bunch of internal options at half the price of the current shares...scared me off.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
