Basing .035 on the recent new share release. That's what they offered the big boys so this what I base my roving off
Seems I was correct...now to see what it does..
Considering they sold more for .031 I think will bottom out around .033 and then I might think about some
You don't get to call two different floors...pick one that it will stabilise at.
I can't see much support in the buy side, only 12 million shares between current price and 2 cents...and there is heavy manipulation going on with 15 million share orders being traded back and forth. In auction it is being dragged down one pip at a time each day. I cashed out and will be back in when it starts climbing again. Got sick of watching profits piss away again. Still confident it's a great long term prospect but missing out on acquiring more shares for the same money if I don't try to buy in lower as it sinks.
I'm gonna say 2.8
I hope it doesn't, but our last capital raise to private investors pulled the share price down just below the share issue price. Wouldn't surprise me if it happens again.
On the plus side can pick up cheap shares.
I'm gonna say 2.8
Think you called 5.0 (may have been 4.0) as the floor....
Yep I was wrong...but how long should it stay there before you can call it a floor, cause it hung around that for weeks.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
