Lets put it this way... 6 months ago you were tossing up if you should get an $1800 big brake kit, or just $700 on new rotors and pads...
You chose the new rotors and pads as it was more cost effective.
These sorts of decisions aren't possible in a 1000hp build, you just have to keep throwing money at until you reach the goal, or go broke.
the chips must be crunchy and fresh, and be consistently warm throughout.
cheese should have an even coverage, and melted into the chips. alot of places use mozarella for some reason, which is a big downer for me.
best to use a sharp cheddar, as it breaks up the meat, garlic etc
the meat should be about 3mm thick, and moist.
avoid places that use meat left in a bain marie, that meat is essentially steaming in there.
and finally, the sauce.
its completely up to you, but i prefer garlic with a little BBQ. the sweetness is nice, no chilli because that shit makes me shit like an animal (on the side of the road, in parks, on simons door step)
let me know where you go.
i might come out for one lol
IN Sydney, so unless your planning another road trip.
normally go the garlic and BBQ on a kebab, thinking might add chilli on this however.
bunch of kebab sores near here just gotta find one that looks dodgy enough to be good.
(and not have the horrifically processed meat)
Low expectations
Pretty much this
I don't get the craze, I only got one or two of them to be a part of it because I'm not a hipster douchebag
You feel sick after consuming 80% of it
And it's shit meat anyway
Kebabs are better
Y'all really need to try one without processed meat and actual lamb.
greek style.
also,
TV2 up another 20% today, by lunch time.
Aka a meat platter / sampler from a Greek joint
I commit to these on the regular
You been to Kalemira? tis down your way
I just buy those meatpacks from Safeway cold food section.
Or those pre-cooked cheese burgers you can get in the frozen section.
Mmmm
pls die
greek style.
also,
20% of 5 cents is 1 cent M9
lern2invest
Ever tried those canned cow tongues? It's like budget oysters. Just don't tell your guests what it is.
Sprinkle same kale on it or something with some imitation jus drizzled on the plate.
People love to be adventurous, especially when they don't know they are.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
