Election time... Always a tough time with an important decision to be made.
I really need to sit down and have a good think about what kind of dick and balls I'm going to draw on this year's ballot paper
hair or no hair?
Just heard an anti-Turnbull ad on the radio spoken by the ETU...had absolutely nothing to do with unions...or electricity for that matter.
Sex party gets my vote again; at least they stand for somethig tangible and desired
In Victoria the Labor party is directing it's preferences to the Sex Party
Curiously, how hard does the union push its members to vote a certain way? I knew of people back in the day who pretty much got kicked out / ostracized for voting Liberal; stopped getting offered work etc.
I think we've been sent one thing in the mail maybe a month ago, basically saying to put liberal last.. Not so much Labor first.
Liberal want to introduce some pretty f**ked up laws against tradies so it makes no sense for us to vote them in... The ETU isn't actually affiliated with the Labor party anymore though... They pretty much decide who they suggest heir members vote for on a case by case basis, I guess it's more often than not Labor as liberal doesn't really do anything for us blue collar peasants.
Labor wanna take away my pending negative gearing though, so I'm f**ked either way...
but I thought tradies all wanted to vote liberal... that's what the add told me
So I have a no junk mail sticker on mail box, when you travel overflowing mailbox is a giveaway.
why do all the political parts still deliver to me anyhow.
on a slight plus Note, I land on the morning of the election, no adds, billboards or crap for me.
look up policies from airport on way out, vote on way home go to sleep.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
