There was another time constraint involved in the changeover.
Someone in the accounts team is leaving and the replacement started this week, so they started training them fresh on the new system (they're already comfortable with the new one (Xero) but have never used the old system (MYOB Premier v19 via TS))
there a few ppl here who have been to SG.
Any-one know a hotel (other than transit ones) that lets you check in any time and check out 24 hours later? not 3 pm check in 10am check out.
for some reason my travel agent messed up and booked my trips on 2 separate trips so cannot check luggage all the way though.
land in SG at 6am fly out at 11 pm.
So need somewhere to store luggage/get some sleep/shower after eating too much.
all the ones I know of are in the terminal which I cannot use
so the transit hotels are after you have cleared customs.
Which fine normally as bags checked all the way though I stay in the cleared area and I can use them (the ones in SG are very nice, sub $100 and you can even use the pool)
this time (on the exact same flights as last time) they booked on separate tickets
So I have to leave the customs checked area in SG, collect luggage, but I cannot check them back in till 3 hours prior to my flight so 8pm.
thus I have 13 hours between that I am stuck with luggage.
my fall back is to take them to the office dump in my bosses office and be a tourist for the day
would like some sleep tho, red eye flights 2 nights in a row leaves Martin grumpy
there seems to be one opposite changi village hawkers market but you have to book direct not online so that could work.
So handful of containers landed on site. Made a wall with them.
Someone put on Kenny Loggin's Danger Zone this morning, but I think his song Playing With The Boys would be more appropriate
18's dont feel big enough for the gloria now... 19's would be nice so had a look at how much step lips would be to re-barrell. faark cheaper to buy another set brand new in specs I want. oh wait, theyre discontinued after being in production for 2 years :|
other wheels I really like only come in 20's. heaps of 'mericans run 20's on their M45 and it looks balls, but if done right... could be v nice. would need like $2.5k in suspension arms to get maaad fitment though.
would love to look similar to this (not that low):
1525445_792861030828141_2842875914403493
I sized up the wheels and without too much hassle (just need a bit of stretch) should be able to get 110mm dish on the rear and ~90 on the front.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
