12 hours ago, dezz said:
I bought a $3200 mattress about 5 years ago when I moved into my place... 100% latex, no springs etc etc...supposed to be good.
Can't remember how long it took because I've left it so long, but it sagged, and now I pretty much wake up sore every morning.. Comfortable feeling bed, but obviously not doing it's job..
So now I'm finally going through the warranty process... Expecting a call on Monday to arrange a time for them to come and inspect it. They should replace it, but then I'll have to go through the process of choosing another mattress... Most people can sleep on whatever and feel better than I do on a daily basis, unfortunately I'm not that lucky... so it's a big decision..Which obviously needs to be made in a timely fashion
fucking stop lifting you meataxe cunt
You should get a cheap single bed foam mattress and try cutting out a face hole out if it.
Used to love sleeping on my stomach with head to the side as a kid, no pillow. Can't even lie like this for 15 minutes these days; squats and deads turned my neck into tinman.
There are a few proponents of sleeping on the floor - they reckon it's difficult at first but you get used to it. Can't see them having partners without their own dating site though...
Had to sleep on the floor when I f**ked my back a few weeks ago...
The theory behind it is that it's stiff, zero give...so you're body is 100% supported. When you sink into a bed your body can slump into whatever posture the give in the bed allows, muscles then work to try support the body, wake up fatigued as if you've been using muscles in your sleep... Which you have
we sent a bit of coin.
but got one that has different spring rates to both sides as different weights of Katie and I.
I was skeptical, but I used to love traveling for the good hotel beds.
Now I look forward to coming home for the good bed,
Split spring rate, pillow top, from snooze, never looked back.
10 hours ago, 32JET said:
Does anyone have allergies or intolerance's to food?
Took me 22 years to find out i had a food intolerance to fructose..
Lol
Brother found out a fructose intolerance recently...seems to be the new buzz allergy
I should test myself, probably have a slight lactose intolerance, but l'd like to think I'm manly enough to eat anything except a salad
  • Like 1
Hate when this happens. He wasn't even doing anything wrong and they just took his license. Luckily his mum is super cool and will drive him. Lmao what a f**k head. I restrained myself from commenting because i can't be f**ked to talk to an idiot.
Ex was fructose intolerant, so most meals was on fodmap diet. It's doable but pretty annoying, depends on how bad it is. If you can get away with small amounts of wheat and avocado or mushrooms it makes things more interesting
Just paid for bed and mattress from snooze. Decent sale on at the moment, was like 45% discount total. Just annoyed it'll take 6-8 weeks to make, but at least get to choose material
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
