Just now, Birds said:
Power is directly related to torque, son. These engines aren't different enough that if producing the same power there will be a large difference in peak torque. You'd be talking ~50nm at best. The 25 will bring on the torque and power earlier and that's about it. Hardly cog-stripping material. Unless he's button clutching it with a locker and slicks he'll be right.
Tell that to a 7L V8 in an old ute that only makes 200kw but can tow a GTR on a trailer behind it without breaking a sweat.
RB20s are junk, and their gearboxes are even bigger junk. There is a large difference in low down torque, stop looking at dyno sheets for proof and go test drive the engines back to back. How many people have you seen say that they need to ring a 20's neck above 5k to get it moving. Considering you have a high flow and brag about its response.. I don't think you could live with a 20 even though its "only ~50nm at best"
If you're gonna convert it to 25, which you won't because you've already made up your mind, buy the box... otherwise whatever.
Completely different engine. Let's keep the comparisons sensible shall we...given we're talking about two engines that, all things equal, are 500cc different. That is why I'm happy to generalise that, with similar power levels, one won't be smashing cogs over the other.
FYI...I have driven RB20s and RB25s, back to back. I agree the former is a piece of shit that takes forever to make power, but this fact is largely irrelevant, because when it does make that power it is nearly the same peak torque being transferred through the gearbox. Load and peak torque are what smashes gears, not where in the rev range that peak is...which is ultimately the difference between a 20 and a 25.
And if we're going down the path of experience...well...I've fitted countless 20DET gearboxes to modified vehicles, from VLs and 31s to S15s and 25DE+Ts. Done a lot of 25DET gearboxes too. It is the far superior gearbox, but as long as you're not smashing synchros and dumping button clutches with slicks, you're unlikely to break the 20DET box with less than 250rwkw in a 25.
Anyway, I can't see Pat putting in a 25, as he doesn't want to overcapitalise on a 5k(?) car. Hence the garden variety detailing jobs.
  • Like 1
Quick question for the IT dudes in here. Revolution IT did the load testing on the Census website and ran it at 150% of the expected users to login at the same time. They charged the government $500,000 to run these tests. Does that seem exorbitant? I can imagine they'd have a powerhouse of a computer and server system but god damn that's a lot of money for something that still failed anyway...
well they failed so yes exorbitant.
to load test something that they expect 10 million hits in a couple hours...well you have to replicate millions of users, honestly to do it properly I would expect it to be more.
I agree with everything in this post
I was tempted to see what would happen if deliberately inducing lag by ramping boost late (like a centrifugal charger) would be a way to get 400+kw from a R33GTST box.
Would be interesting to see what the torque curve would be like if you run say 14psi at 4k then ramp it slowly to 25psi at 7k. May be a way of keeping a box going. Should result in a big flat line for torque as opposed to a massive spike then it falling off.
Pretty much this.. I'm not in the webhosting business so can't explain HOW they'd actually test millions of users at the same time accessing their server(s) I'd guess they'd have a bunch then just use math to multiply the load up to however many users..
Lets not forget the failure could be due to hackers etc attacking 'for the lulz'
And also that there's a lot more underlying than just server load.. you've got to have enough network infrastructure and bandwidth to flow all that traffic which I reckon is where it would have failed. Like the Monash.
Don;t call these guys Hackers, thats giving them way too much credit, it is script kiddies doing a Ddos via a zombie network. (if it was an attack)
It's that easy even Birds could do it.
http://www.symantec.com/connect/blogs/renting-zombie-farm-botnets-and-hacker-economy
the funny thing is load testing is a very similar process, get a whole bunch of boxes and start loading/posting data to the site. monitor.
What is interesting is that this might not actually be a DDos attack just a crappy scoping exercise.
so apparently they estimates the traffic at max 1 million users per hour, so the load testing at 150% would be 1.5 million users.
now lets say there around 10 million users submitting online.
I would guess around 1/2 would have sat down in the evening and gone ok Fk it lets do it.
so 5 million in 2ish hours or much more than they scoped.
they could have Ddosed themselves with legit traffic.
that also said doing it in the "cloud" is meant to mitigate this as they can just virtually throw more CPU's at it till traffic is gone.
Keeping all the bad parts of a turbo and getting rid of the good is a Mohsen spec idea.
Might as well fit a smaller turbo that will deliver the same boost and power much earlier on. The reason you'd be getting 400rwkw from the box is that the engine is seldom going anywhere near that and you've effectively dulled your turbo to perform like a small one, but with more lag. If the box can't handle 400rwkw, the day you take it to that peak is likely the day it will break. Unless the box weakness is its input shaft, 4th gear being a 1:1 is less likely to strip cogs.
Think of it this way - a chair is rated to seat 100kg. Someone 140kg sits down on it, quick or fast, that chair is eventually going to break under their weight. You can break it with 80kg if you jump on it (ala dumping clutch).
A turbo ramping up fast isn't quick enough to snap teeth; only the torque limit of the box or a sudden surge from standstill will do that.
Oh I forgot to...carry the 1
  • Like 1
That's the thing though, most dynos have *peak* torque at ... I dunno, 4k? Usually when the car hits full boost, middle of the range.
If you backed power off in that range, your torque would not look like that. Instead of being 620nm at 4k then bleeding off to 500, you could have it peak at 500 and stay at 500 the whole way through the rev range.
Look at most people's dyno sheets, the max power figure is not where the most torque is.
At least in my car having huge power at 4k only rips tyres anyway. I'd probably result in a car which is faster through being easy to drive, and won't smash gearboxes. I am aware that losing traction means driveline stress wouldn't happen anywhere near as bad, but usually 33 boxes die from stripping gears. Under load. Usually 3rd. Usually when cars are on full boost/torque and not losing traction anymore.
So my idea was simply to spread that out over the rev range instead of having it all come in hardcore when the turbo spools up.
Going a smaller turbo isn't an option for me, my car has the tendency to choke the living shit out of anything smaller than a GTX3582R. I had to run a GTX3076r with a limit of 5700rpm to avoid the car melting itself.
Ideally you'd just have a gearbox that can handle the torque. But rarely do we get exactly what we want in modding cars :P
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
