Attempted to speak to telstra this afternoon about broadband options... Theyre already f**king shitting me.
There is no sales representatives, they instead sent me an sms with a link to their website. The page doesnt answer any of my questions. And what the f**k is wrong with number options? Voice commands clearly never work. Its like they want to prime their customers to abuse staff once answered.
  • Like 1
Good luck with that.
I'm convinced customer service at these large multi-level organisations is set up in the least efficient way possible so as to deter you lodging complaints, not unlike the process for contesting a traffic infringement via court.
With Telstra you get stuck speaking to frontline robots who handball you to other robots and with the automated SMS/email bullshit you end up with about 3 different case IDs and 4 different people assigned to each. If they can't resolve an issue you won't ever get told this, it will simply stay in the ticket queue forever and a day.
7 minutes ago, dezz said:
Tomorrow is the most important day of the week for share prices... I don't like to see red over the weekend... Even grey isn't as attractive as green
If news doesn't come for us tomorrow it will probably go up again because of Friday FOMO. Historically we've had news released early in the week, Monday/Tuesday etc.
London tonight will be a good indicator. If they continue the upward see-saw with us, I'm almost certain we'll open up again tomorrow.
Wasn't there any news in the 23 page release I told you to read on my behalf?
Even I read it.
All I got out of it was that the price crashed last time because they went from ~75mil shares to 3.1bil. I'm sure some major steak holders knew it was going to happen.
Mmmm steak.
Unless it's related to oil or drilling progress I don't care for annual/mid/quarterly reports. They say nothing anyone following the company closely doesn't already know.
30 minutes ago, Daz said:
Smashing it :)
Yeah it's been awesome, am very lucky. I still think the share is ridiculously undervalued given the company prospects and asset potential, which is why I haven't sold out. Just gotta think of the profits as reinvestment instead of taking it out.
88e is doing a good job of flying under the investment radar, which will send it into orbit if/when we cop good news and mainstream media starts reporting it. That's pretty much how it ten bagged last time.
  • Like 1
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
