Attempted to speak to telstra this afternoon about broadband options... Theyre already f**king shitting me.
There is no sales representatives, they instead sent me an sms with a link to their website. The page doesnt answer any of my questions. And what the f**k is wrong with number options? Voice commands clearly never work. Its like they want to prime their customers to abuse staff once answered.
  • Like 1
Good luck with that.
I'm convinced customer service at these large multi-level organisations is set up in the least efficient way possible so as to deter you lodging complaints, not unlike the process for contesting a traffic infringement via court.
With Telstra you get stuck speaking to frontline robots who handball you to other robots and with the automated SMS/email bullshit you end up with about 3 different case IDs and 4 different people assigned to each. If they can't resolve an issue you won't ever get told this, it will simply stay in the ticket queue forever and a day.
7 minutes ago, dezz said:
Tomorrow is the most important day of the week for share prices... I don't like to see red over the weekend... Even grey isn't as attractive as green
If news doesn't come for us tomorrow it will probably go up again because of Friday FOMO. Historically we've had news released early in the week, Monday/Tuesday etc.
London tonight will be a good indicator. If they continue the upward see-saw with us, I'm almost certain we'll open up again tomorrow.
Wasn't there any news in the 23 page release I told you to read on my behalf?
Even I read it.
All I got out of it was that the price crashed last time because they went from ~75mil shares to 3.1bil. I'm sure some major steak holders knew it was going to happen.
Mmmm steak.
Unless it's related to oil or drilling progress I don't care for annual/mid/quarterly reports. They say nothing anyone following the company closely doesn't already know.
30 minutes ago, Daz said:
Smashing it :)
Yeah it's been awesome, am very lucky. I still think the share is ridiculously undervalued given the company prospects and asset potential, which is why I haven't sold out. Just gotta think of the profits as reinvestment instead of taking it out.
88e is doing a good job of flying under the investment radar, which will send it into orbit if/when we cop good news and mainstream media starts reporting it. That's pretty much how it ten bagged last time.
  • Like 1
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
