I saw the yellow one there last week. I had a good look as I have the red one too . It is steel and has a longer low profile body but the minimum height is a little higher, maybe 10-15mm. It also weighs a fair bit more.
  • Like 1
I think he sold at what he got em for before they go down again.. Birds doing the day trade thing still I think
Anyone wanna buy my GS? Might be time for something different.. funny enough only ONE for sale in Vic on carsales :\ dude wants 37k man mine shits on it and would be good if I could get that kinda cash for it..
Edited by UNR33L
  • Like 1
Buy on rumour sell on news rings true for today.
Could see a rise during the day, but looking like a dusty open lower than Friday's close. Announcement is very positive but obviously isn't meeting or exceeding hype...for now.
Thank f**k my order didn't go through on Friday to buy back in.
  • Like 1
M8 wut r u doin
$8k on supercharger and brakes one week, motoX the next, now car sales.
Just get a civic, put a stock exhaust on it and move on already[emoji14]
Inb4 GS worth $65k in next 2 years.
Birds you sold out man. Where's the faith. Icewine1 results due October. Heard they put a 2mil cap on today so probably slow n steady gains this week.
14 minutes ago, Leroy Peterson said:
M8 wut r u doin
My faith is in my luck, the market to do irrational and stupid things, and my ability to make money off that
Also switching between modding a car and selling it makes perfect sense; it's boredom with the vehicle and methods of absolution from that boredom
Yeah it's more, do I spent 8k on it now and make it insane, but that will force myself to keep it longer (But funner)
Or get rid of it, add 10k onto something newer (eyeing off an 15' STI) slower on the street sure.. but few years newer and something different. I've always been one of those guys that get bored, buying and selling shit all the time.. motorbikes are better for this loose less $ :)
Had her for 5 years now, much longer than some all evo owners, only got 53,000 on the clock though.. I must barely drive!
Edited by UNR33L
yeah thats fair enough i guess. I dont really like the idea of spending more than $20k on a car i'd then want to drop heaps of money to try and make better, when I can achieve similar things with a bigger mod budget on a cheaper car.
LOL here comes the last VWL evo owner ready to pass on the torch (alvin doesnt count no more)
88e drops 1c, manageable.
What entry point you looking at for 88e
No set point, I think it's too volatile to buy in right now; I'm terrified of London's inevitable correction and us see-sawing down off it. Might buy in tomorrow if we see a little recovery. I'd rather lose a little potential for profit and buy in when we start to recover than lose a lot of money.
Right now 4.7-4.8 seems to be the floor for the day and could be a good entry for short term profits if we recover tomorrow, or even long term as we might not see these prices again for a long time. Buy when people are selling as they say. Too risky for me though. I've already got rewards so don't need to take the risk.
  • Like 1
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
