4 hours ago, Mohsen said:
suddenly inspired to pull my finger out and finish the R32, get it back on the road and enjoy it.
LOL JOKES
if your car is finished your too old..
as for broken cars....
ordering parts for 2 cars currently.
41 minutes ago, Borci88 said:
Isn't it hard as fook to wire a Neo into a 32 GTST? You can put an RB26 in and change like one plug, but I think a Neo is a fair bit of work aint it?
33 and 34 are both annoying to wire in a r32. R33's don't do neo's as its easier to drop in another rb25.
I find wiring the easiest bit. it's making the mechanicals work which is the most worrying haha
My whole conversion wiring is kinda toast. The looms all brittle and wont move outa the way when i'm working on it.
Ive been thinking about getting one of those wiring specialties rb25 to r32 conversion looms
Mine was too. dont be a pussy and get one of those made-in-someones-garage-without-seeing-your-car kind of jobs. go full custom, mill-spec, all-out. pick any ECU you want, any features and sensors and functions you want. best thing I ever did. If anything, I regret not getting a more feature-rich ECU and more functions (but funds at the time were limited). But now its a piece of piss to go a totally different standalone ECU if i wanted to.
19 minutes ago, JAS-25T said:
it's all down hill from here.
88E in pommy land slumped last night, today probably isnt going to be solid.
50 minutes ago, JAS-25T said:
Oh sheet. 88E just got mentioned in a TV2 thread on HC.
TV2 was dogging just fine without 88Es help
No cross promoting
15 hours ago, Leroy Peterson said:
pulsar will be on the road before the end of the month. you're not getting a 2017 GTR so you might as well do something...
it not too late... wont be able to afford a house though lol
When f**k arse in another department sends a passive aggressive email trying to get you to do their work for them, thinking they are above you and CCing your boss in on it...and your boss who is above them politely tells them to f**k off
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
