but someone else wired my car, i think i know what im talking about.
im super curious to see how my new-age-thinking crank trigger goes. super bike CDI coils should be good for an extra 20fwkw at phillip island.
21 minutes ago, Leroy Peterson said:
there isnt anything wrong with powerfc. i retained mine for so long because it was basically the only option. i didnt have a stock ecu to put a nistune into.
but i feel i've seen the light. it shocked me earlier today to see you can still buy powerfc's brand new (for some cars).
ever since haltech took on motec's pay model, its hardly value for money. mind you, every time I've asked someone "why do 90% of professional motorsport teams use motec?" the answer has always been "because they're the best" *queue Tina Turner*
and whats with haltech and CAS disc issues? (i know the disc is a POS, but does it work or doesnt it?)
Matt do you only chime in on SAU when you feel like arguing with someone?
Key word being motorsport professionals...the kind of guys who have already bought everything else they can legally buy...and replace fender bolts with titanium ones because it saves 300 grams! On the street or amateurs around a track, another psi of boost or better tyres will do more for your performance!
i was more pointing at: what does motec have/do that others cannot match?
actually f**k all that stuff.
for us amateurs best way to get faster times is seat time...
true story.
I think the question we need to ask here Leroy, is why do you hate power FC so much?
i dont hate it. I just think its poor value for money. I dont get how so many second-hand ones sell on SAU. I struggled to sell my GTiR one because nobody wants them (even though they can be used on any FWD/AWD SR20), and they're discontinued too.
They're archaic. They're from a generation of japanese products that required you to have a $2000 Defi gauge setup to monitor/display information that almost every ECU can do itself now. The Autronic I've switched to now is still pretty old-school but reading the manual and some of the parameters that can be tweaked or programmed is pretty exciting.
I think I read someone here describing a PowerFC as a stock ECU with a piggyback unit built inside it. Sounds pretty accurate to me.
19 hours ago, Leroy Peterson said:
whats your budget? that kind of stuff isnt cheap... LED and halo rings is one thing, full cut-n-shut Vulcans or projectors is something else.
You chasing full-professional workshop or dont mind garage/side-project stuff?
damn cats running wild these days. i think the hippy should be re-introduced as a control measure.
Not fussed who does it, as long as its a good job.
Quotes atm are around $750 to $1k,. For a dual/quad projector setup
They're cheap, easy to re-sell, quick to install, most Jap specialists can tune them with a quick turn around using the same base maps for similar setups..
I think it's very much a case of don't fix what isn't broken. I don't know about you and the VIP generation, but all I need an ECU to do in my car is make the engine turn. The bells and whistles, gauges, 20 sensor inputs and antilags etc. will do sfa for the performance majority of tuned street cars and that is why PFC is still popular. The requirements of most users peaked with this product.
4 hours ago, Leroy Peterson said:
i'll be sure to recommend the PowerFC to Daz for his 1000hp street car
1000hp supra is not an average street car - no matter how you try to slice it
6 hours ago, joeyjoejoejuniorshabadoo said:
For your average street car / weekend warrior you simply don't need any more than a power FC offers. Shit I didn't even bother with a hand controller
nah f**k that.
haltech FTW.
support straya.
if you dont like it, leave.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
