I found the AD08R to be absolute garbage in that last turn trying to get any power down (lowered the boost as much as possible and had big issues)
That said, can confirm am noob driver. My suspension is possibly f**ked though, but 5kg front and 4kg springs at near stock ride height is pretty fkin boaty and non track optimal, like everything that I haven't near immediately changed after actually trying to use it.
Birds, turns out that "Catch can" was actually pretty much venting to the engine bay as that's where it was disconnected (back to the intake, at the intake) and just pissing oil everywhere. Bought a replacement with actual baffling that will actually be setup actually correctly to actually catch oil (or at least put it it back into the intake and not into the engine bay), and actually get some actual tyres for the next time. (i.e, Nankang AR-1)
Or just cheat and get a GTR for those slow corner exits
Also that chaser was parked literally next to me. Was a nice guy!
Greg, I followed your car down the main straight, into turn 1,2,3,4,5 and partly down the back straight and I thought it looked to be handling quite well. As far as traction out of the last turn, with the amount of power and torque you have on tap, throttle control is the key and yeah the biggest r spec tyres you can fit would be a good f**ken idea.
19 minutes ago, admS15 said:
Why did he need to get towed. What happened?
started blowing huge amount of smoke at end of the main straight so shut it off.
turned out to be a minor thing, over filled with oil
  • Like 1
I had turned the boost down so I was running a fair bit less than 415, more like ~320ish but the delivery is still much the same and first time ever out on the track in the thing, I almost put it into a wall on the back straight coming on power too, so that was why I went home to get the laptop to turn that boost down before death. Obviously a stall converter not the easiest thing to feather but it's 'doable' with some restraint.
It did feel rolly and sloppy as all hell, but maybe that's what everyone is dealing with and I should just learn to drive :D Sure was fun though.
1 hour ago, UNR33L said:
so where's the best place to buy AD08s? seeings as I need new rims anyways - dont they have a buy 3 get 1 free thing atm?
I feel like Hamish and me were the only ones that liked the NT05s
Dunno about best but Traction Tyres (inb4 Greg) sell them. Not cheap though. I got mine for $220 a corner a couple years ago but they were 2013 production so cheaper.
You don't have to go AD08s, RS3s are probably better value, but yeah much better options out there than NT05. Think Ric liked the Nittos too.
Yokohama buy 3 get 1 free special atm doesn't include ad08, only some shitty suv tyres. I got my ad08 through bob jane of all places, was actually better priced than traction tyres. I noticed the tyre factory advertising RS3 last week on ebay for 269 for 265/35/18.
Given I could plant 1st and 2nd on the street without breaking traction (without warming them up) in a 320rwkw car with 320rwkw at the wheels I was damn impressed.
edit: 320rwkw
Edited by joeyjoejoejuniorshabadoo
to add more 320rwkw
FWIW I found no real huge difference in NT05 and AD08R in terms of grip for the street. Housemate with RS3 and AD08R noticed no mega difference, maybe the AD08R lives a bit longer due to the higher cost so you aren't swapping as much.
No back to back laptime data etc though, all by that seat feel.
Been looking at RS3 as well, as usual barely any around in the sizes I want, sent a few emails this morning for some quotes, most with this response:
"Sorry they have no stock of either sizes. I have checked a couple of sizes close to the size you have asked for and stock very limited."
Seems to be more Invo / NT05s
http://www.ttf.com.au/#/shop/tyresbysize/245-35R19
Edited by UNR33L
edit: 320rwkw
This to me isn't so much evidence of NT05s being good but hub dynos being liars
2 minutes ago, UNR33L said:
lel
anyone tried the  Michelin Pilot Super Sport ?
tried them on a mates car and wasn't that impressed for the $$$
not bad, not great
121 mph trap speed @ circa 1550 kg inc fat-ass driver.
your move...
They are more luxury performance tyres, like the Continentals, where they will perform well in dry and wet but you also get less road noise than cheaper tyres.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
