9 hours ago, L33SH said:
Thanks guys, will look into the suggestions
Might be exy but check these guys out
https://www.facebook.com/Affinesse/?fref=ts
https://www.facebook.com/DansGarageDetailing/?fref=ts
2 minutes ago, Mohsen said:
post sedan for sale- clearly state it will be bare from the front doors forward and no wheels
"hey bro, how much for the wheels? are the indicators still available?"
So people are basically being you... to you... and this bothers you...
53 minutes ago, joeyjoejoejuniorshabadoo said:
i no understand? y u no make birds do it?
Thought you'd be more shocked that someone in VWL is actually heeding the advice of other VWLers for once
Hardly, all in would be to stay in it and actually make some money...when I told people not to sell at a loss they didn't listen. If they followed my exact moves they'd be paying capital gains.
I'm just glad I sold my CBA's when I did at about $85 they did go up a tiny bit more but not for long and now they're down to $75, more luck than anything else
36 minutes ago, Mohsen said:
not really,
i never buy anything anymore lol
You literally just bought an R32 in the exact condition as the car the guy is making inquiries about
  • Like 1
Dumb question, is there any good BUDGET detailers? Somewhere where you can just go on a very low notice and get a reasonable to OK job of interior detailing because majorly CBF and car looks pretty shit 95% of the time anyway?
By "good enough" I mean good enough to think "oh yep, that's cleaner now" but with 0 desire to actually take a photo of it.
I would suggest doing it yourself.
mainly because the vaccuum will likely create a spark near a fuel leak and you car will likely be burned saving you (and by proxy, us) from many more years of heartache
I paid 32 bucks at one of those shopping center joints for a exterior wash / polish actually turned out not half bad. Why not just go to somewhere like this?
My car was shocking after taking it through dirt roads.
inb4 "dose guys scratch your car doe"
Yeah the thing is my lovely better half is eventually going to respray the car so scratches not really that concerned right now.
Would take to shopping centre, Was curious if any are known as being better or worse than others. Maybe someone knew, etc.
I currently DIY it and I do a decent enough job for myself but I always figure paying someone would get a better result, every now and then.
Given my effort is a few wipes over the plastic to remove dust and occasionally wash the mats and a little 12v vaccuum I own, I don't have massively high expectations, I only washed the mats because I managed to break a take away curry all over the mat... and washed it after about 10 days later, so that'll give you some idea of the quality of job I am looking for
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
