11 hours ago, UNR33L said:
Yes that's pretty shit, Optus should be able to provide you 30mbps down 1 mbps up pretty easily - worth a phone call
30 down 1 up is considered 'standard' cable speed and 100 down 2 up is considered 'ultiamte' cable speed which you'll need to pay extra for but still possible on cable.
For reference my Telstra cable gets about 30-35 down and 1 up
Leeroy has a special situation where he has reasons for the shitty-er cable speed I'm sure :D
Edit: Basically what Simon said
Well I have one of those Motorola Surfboard modems they supplied us with 6+ years ago, but they refuse to even chip in money to upgrade it now even though the service is not what we're paying for. They want $200+ for the modem plus an installation fee to upgrade. This was after two phone calls and a bit of a raised voice.
16 minutes ago, Rekin said:
ISP's can't just be gifting out modems with no cause. Either sign up to a new contract (which may only be applicable to new customers) or there is a connection/speed fault caused by the modem.
Well they can because phone companies give rewards based on staying with the company for a period of time, usually by waving different costs or adding in extra value to their existing plans.
put some more pressure on them, ive got a spare telstra modem you could have which is better than that but you're with optus.
call around for a better deal and make em do better themselves or leave. mate you'll get easily better speeds elsewhere and prob more data with new modem too.
Only reason why we haven't looked elsewhere is because it's bundled with Foxtel and I believe phone line
Problem with modems is that they have to buy them from suppliers & they need to link them back to the reason for supplying them onto you. If there isn't a valid reason, be it a new contract deal or a fault replacement, the operator on the phone can't do much.
meh any of them can do that, and can port phone numbers across if you need it.
just call optus and tell them your speed is shit and not 30mbps and to fix your shit
Edited by UNR33L
So they stand to lose 3 times as much shit if you leave...........
No one is going to cancel their internet contract because they want a new modem.
A new modem serves no purpose if there is no fault with the old. Hence why they will only replace if there is a fault.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
