4 hours ago, Leroy Peterson said:
Damn, that sucks. But even if you do a basic inspection of the second hand goods you wind up like birds waiting 12months for barry
My kinder surprise was an overly shaved head that was way too high comp and some rough machining on the deck...machinist took forever to get around to it. Not at all saying my man hasn't sidelined his engine builds for drive in drive out mechanical type work, but that's been a major hold up for us. Talk is end of the year for completion so fingers crossed.
But yeah luck of the draw with second hand engines. Have to ask yourself; there's usually a reason the engine is for sale - either the car got thrashed out and trying to offload problems, a part out (why?) or stacked, in which case strong possibility of a hard life pre-stack too. Lot of shit engines out there. My seller didn't lie about having issues with the engine before I bought it - it was worth more in parts than what I paid for it, which is why I took the risk. On the bright side I got a chance to make it powerful and near bulletproof.
54 minutes ago, BBGTR said:
Has anyone got any recommendations now Mick has hung up the spray gun?. I want to do a windows out full car respray with my 32.
Andrew
I can recommend my panelbeater if you want to PM me. Just had a respray done by him and I'm very happy with the job. He does a lot of hotrods and muscle cars and those guys are pretty fussy. Very passionate about his work and it shows, but he's always got a full shop so could be a wait.
The word Bulletproof should never be written on the same page as an RB, let alone to describe an RB!
If anyone is bored, drifting live streaming from Sydney:
http://live.worldtimeattack.com/
Keiichi "Drift King" Tsuchiya says hi
5801fa05a96a2_ImageUploadedBySAUCommunit
10,000 people here. Not bad. Sydneys reputation for bogans holds true.
  • Like 2
I said bulletproof not starvation proof lol
pretty good live coverage, apart from the 10mins of ads just before
P plate Golf R gave the toot of acknowledgement after dropping behind in a rolling - is this the first non D-bag Golf owner in the history of the world?
You don't count, Hamish
  • Like 3
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
