Scabies leave trails on your skin as they burrow and are itchy nearly 24/7. You end up with them all over your body too. Bed bugs/mites will just bite you (not sure if they lay eggs under skin like scabies?). You'll soon know either way. The hottest of hot baths doesn't kill them, only rubbing yourself with insecticide...over every square mm of your body...yes in there...will completely eliminate.
And yes old mate google the hypochondriac. Put in itchy arm bite and you get some frostbite ridden decaying limb pic. The health websites aren't much good either with their symptomatic descriptions that match up to...I don't know...f**king everything
- Headache
- Dizziness
- Nausea
- Weakness/tiredness
- Loss of appetite
My engine let go again.
Congealed exhaust gas in coolant looks like poo.
It's noticeably different from coolant and oil mixing, which I have also seen within the last 10,000kms.
  • Like 1
I think more like stock motor and never ever open the motor in any case at all.
And some responsive Borg Warner thing on the side of it.
Or who knows, maybe just put an OEM gasket back on what's currently there, unless the block is cracked or there's a portal to the underworld when they remove the head which is entirely likely.
Drove Grant's car the other day; motor felt very healthy. How is it that a guy who can't even hear his engine can keep it in better nick than you Greg :4_joy:
  • Like 2
Don't have to open the motor to put studs in.
26 minutes ago, blah_blah said:
Perhaps listen to a few of the concerns and suggestions that the engine builder had at the time when he built your motor
I have, every time which is why they were so confused when it arrived back on their doorstep yesterday..
Eliminating things that are "custom" is now my primary goal here. I wonder if things like Scotty's turbo housing/gate/manifold setup causes heat/backpressure/something (maybe it does at 400rwkw at 4000rpm....)
Perhaps the traction control system doesn't work as cleanly as advertised..
Perhaps the metal head gasket didn't seal despite the block and head being super straight and super polished by the machine shop that did it (that also built the engine)
Perhaps the 'custom pistons' that were ordered and sized up for the kit way way back when by someone who was grossly incompetent is causing these fun and games too..
But power was turned down to about 320kw. Given I was pretty happy with that, a standard Neo will be finding its way to that engine bay because I'm really not a fan of "perhaps" (even if something becomes immediately clear as the problem, like last time).
I believe this was brought up as a concern when your engine was built :1310_thumbsup_tone1:
I've had my engine for 3.5 years now and still going strong, only issue was a blocked injector due to e85.
Internally your engine and mine probably same same except for the 2.8 stroker
It was, because back then I had a GTX3076R then with a .82 rear, I took the recommendation and went with a much larger rear to open the whole thing up. Also opened up the intake which would have been contributing to that problem (and picked up 45rwkw lol). But it's possible that the damage had been done, but seeing an engine roll over up top, or an exhaust housing go slightly red doesn't usually result in a blown head gasket. I have never actually run the GTX3076R for longer than about an hour before I changed to a free flowing rear.
And since then the head was lifting under boost (wrong head studs supplied way back then, and re-used by current builder because "ARP studs are reusable". This was discovered when I bought a new gasket and studs because I didn't trust the internet when they said you can re-use metal head gaskets and ARP studs.
And what do you know, the old ones were about 25mm bigger.
Then the block cracked literally 2 days after that was assembled, full rebuild since then, with all the recommendations made, followed.
I directly followed recommendations of people around me... because when you have problems you start looking at people who do not have problems to see where the differences lie...
As to what failed this time, no one is sure yet, other than it's exhaust gases in the coolant.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
