My mates use the roulette table to pregame in vegas.
one drops 5$ on red every spin the other black, split the difference at end of night and as much free booze as they can drink
5$ each every 37 spins on average aint bad for booze.
  • Like 1
thats the most australian thing ive ever read lol.
also, f**k were lucky to be strayans,
USA is a proper shithole
  • Like 1
had no money on alvarez. just for anybody KO. If McGregor went on to fight Khabib (doubt it), i would seriously want Khabib to win. He probably couldnt take a left to the face, but if he's smart and doesnt play the boxing game, McG would be in a very tough spot on the ground. The Russian is crazy strong on the ground. Would be a great fight.
Also had money on Kovalev over the weekend. dominated the first rounds, then dropped off a bit, but Ward dominated the scoring. f**kin rigged bro.
If I ever wrote off mine and had the option to buy it back half cheap I probably would to part out / sell as is at a profit
Pretty expensive engines
Edited by UNR33L
I'll be the first to admit:
There is profit to be made betting against every match I place a bet on.
I put a lot of research into most of the UFC 205 fights. Barely broke even. Some surprises for sure. But that seems to be the way with any unorthodox money making... It's all timing and luck.
Thomas Jefferson said the harder he worked the luckier he got. But trust an American president to say that shit.
When I used to use sportsbet, years ago and muck around with about $100 a year, there was a point where I was betting on surfing...actually trusting waves to deliver me wins. At that point I stopped...
  • Like 1
You only made .1 cents?
Currently on-site waiting for server data to copy from old-new hardware zzzzz waiting for that loading bar. #itlyfe
Will still be an hour or so I reckon :(
Edited by UNR33L
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
