5 hours ago, UNR33L said:
Just the asian old dude at bottle joint down the road from me near Westall station
I'm actually surprised there's no hate towards VB in here, "Ohhh m8 you drink VB you bogan, no taste buds etc"
Ah, cool.
Cheers.
59 minutes ago, joeyjoejoejuniorshabadoo said:
meh....
Augistinerbrau straight from the brewery..... Grant knows
Yep.
So worth going to Europe again just for that.
6 hours ago, joeyjoejoejuniorshabadoo said:
meh....
just to be different I preferred the Austrian variant of that
https://www.augustinerbier.at/?L=1
(this is assuming you are talking about the German one.)
Lol at a few individuals telling the 88E group what a bunch of biased twats they are... Then the group instantly resort to personal insults. Sometimes i have to remind myself that some of these people are unhappy 60-year olds living in QLD running on XXXX
Work site's most ignorant stooge has monthly subscription to Money & Property Investor Magazines... i reckon he blows +$100 a week on Sportbet app during work hours. Then TAB bets at the pub most nights. Been working casual contractor for almost 12 months now, buys new Audi Q3 to cart around wife & unplanned baby due in January.
#justElectricanthings
The average Australian, ladies and gentleman.
There is good reason I stopped posting on HC outside of important company announcements
It was fun while we were championing the share before it hit the big time. Huge sense of comradery and "we're in this together, win or lose". Then massive celebrations as it went mainstream and our faith was rewarded with dollars. But with the mainstream came the downrampers, neysayers, daytraders, share newbies...who assumed to know everything about the share...and paid out on the old hats / company when they bought in too high and lost. Became a cesspool of ignorance, insults and unenjoyable repetition of bullshit. Will return when things get more interesting for 88E.
Birds stop posting on hotcopper
Had a dream about 88E last night. Not sure if it means anything.
I was in Alaska, some other shareholders were there checking into some luxury accomodation. (Which obviously isn't there at the moment.) Dave Wall turned up with his swag and invited me in to see his place. It was twice as good as all the others.
Then he walked out the front and started pitching a basic tent in the snow. I asked him what he was doing. He said he only uses what he needs, one of the shareholders can have his room.
For the long term yes. Short term profit to be made = worth checking in on. Look at the short queue to sell at 3.8 and 3.9 - depending on your level of greed, either is a magic mark to put a sell order in at between now and the announcement as anticipation builds. When such a short queue appears in the buy column, it's a good place to slot in a buy order. Run simultaneous buy and sell orders and you profit constantly as the stock shifts.
Buy on rumours sell on news! Buy when everyone is selling and sell when everyone is buying. The buy/sell ratios are your best friend if you can palm read them.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
