2 hours ago, emts said:
how did they build a 6L V8 with
" 145 hp (108 kW) at 3600 rpm and torque to 270 lbf·ft (370 N·m) at 2000 rpm "
its funny because america's V8's had barely changed since the 40's. and when they went to alloy heads and had to change due to oil crisis, all their new motors went to shit. pretty funny really.
FWD V8? i wouldnt say no haha but when would that ever be a good idea?
the fleetwood pictured was one of the last RWD
but really when you only have 100 kw, though a old 3 speed auto so prob 60 kw at the wheels, and around 100 kg sitting on top,  torque steer would never be a problem.
Not that they were blisteringly fast cars by any stretch, but half of it is that they didn't rev out far or need to for that matter. Those V8s still pull nicely with their torque for the first few thousand rpm. The aftermarket / drag scene in the states was as fast as ever / still breaking records as far as I know, it's just factory vehicles that went down on power in Eder to meet "stringent" new emissions laws etc. There was also the rise of small displacement engines which probably took away development from the V8s combined with low sales.
We did a similar thing here with our 308 VL vs the RB30 and the 304 vs Buick 3800 motors. The V8s were still a tad quicker everywhere in spite of similar power.
tl;dr the yanks aren't that shit at building engines
5 hours ago, joeyjoejoejuniorshabadoo said:
hey... top 10! lol
Birds you loser...
Given I don't post anything but opinions, all this says is that my opinions are popular even if it's amongst a niche lol
holden 5L V8 from same year (WB statesman)
  • Power: 126kw at 4400rpm
  • Torque: 361Nm at 2800rpm
so more than 10% more power for 16% less capacity
(the HDT Magnum having 188kw for the same 5l)
or Ford had  149 hp (111 kW) and 325 N·m (240 ft·lb)  for the 4.1 straight 6.
add to that 200kg weight advantage..
translation the yanks should have talked to the Aussies....
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
