Ok fixed it, change your DNS server to 8.8.8.8 (which is googles 'yellow pages' server basically for getting to websites, instead of using Telstras as default) and if you a want secondary DNS server 8.8.4.4 is googles other one.
Takes 2 secs
Google how to change your DNS server if you need to do it, real easy.
Nice try Australia I guess?
Edited by UNR33L
  • Like 1
41 minutes ago, Leroy Peterson said:
Thanks mang.
88E didnt reach 4.5, therefore didnt sell.
I would sell now and buy back in lower = money in then bank...crash is imminent even with an announcement unless it's awesomely good news
Rats will jump ship / dump - beat them to the life rafts
What else we gonna talk about?
Alex got bored of stirring hamo up. Jonno, alvin and huy got jobs.
Paul (i think?) driving his evo finally
6months till tax time.
Im organising a meet at Point Park for 30th Dec. keep the evening free yo.
  • Like 1
33 minutes ago, blah_blah said:
Or just sell and forgot about 88E
Think you guys have been discussing it for a year
So who has made money?
If you have screenshot your ITR CGT schedule
I've made a respectable chunk plus many small chunks on multiple occasions...you'll see it when I get off my ass and compile the ITR info!
In the VIP spec car or pulsar?
inb4 eaten up by fines
both VIP club and SAU (hopefully).
I was going to drive the pulsar. if anyone I trust doesnt have a working car then they can drive the gloria.
With 50% CGT this is a realistic possibility
Can I carry forward my capital losses from the GFC that I reported during one tax return back then and not since?
Just saw Commsec have self generated .csv files for my transactions...will have info to you tonight...
Pat can drive it lol
Yeah should be right, you dont loose capital losses just because they are not reported in an earlier income year
Alright I'll try and find that data, it might pre-date commsec generated info and I'll have to compile from contract notes...
There is definitely room for software that calculates CGT for short term traders in the most cost effective way
There will be some SAU Vic representation there :)
Let the dumping begin
I hope it finds a new floor for the sake of long termers, obviously hope it drops so I can buy back in again...but classic 88E doing a huge rise on rumour
Hardly a dump... Still higher than 2 days ago.
I saw the order list at 9:30, 2mil over 0.45 on buy. Looking to hit 0.47. 9:55 those buy orders are there but 4mil shares to sell at sub 0.45 come out of nowhere...
Forget the prices, check the buyer and seller ratios and unit ratios...those sellers are climbing hard and we've just hit 4.3...once again...no news is propelling this, only rumour and expectation.
Like I said, get out before the rats do. There are way too many profit takers in this stock for it to rocket up with anything short of truly awesome news. It may end up with a new floor but it's not going to be 4.5, it will be 3.9 or 4 cents etc.
You either play the game ahead of them or you the miss tidy profits to be had in the meantime. Or you're a long termer locking them in the bottom draw...
Don't trust auctions and indicative for 88E. I have about 20 screenshots of obvious manipulation in auction. Consider the insane manipulation has it that a lot of the sellers are in fact the same people buying etc. and the only thing that matters is what it actually opens and closes as.
So the TL;DR is Birds is a RAT?! :O
In other news, LOL exactly what I said before about pirate bay:
http://www.news.com.au/technology/online/piracy/internet-users-bypass-pirate-bay-block-instantly/news-story/a9a4b3e09b86b9f3f6aba798250b5288
Edited by UNR33L
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
