5 hours ago, Birds said:
Besides the fact she's old and probably thinking of Clayton in the 90s when it was dodgy Oakleigh's best friend, lol @ you getting passionate about the suburb's gentrification cause you bought a house in it.
Back in Boronia we owned our shit stains.
mate you gotta push your shitty stocks up somehow right?! :P
the other day, mrs was walking the dog in heidleberg west near northland 3 cars sped into the reserve parking lot guy ran off saying he was sorry then heard gunshots lel. rip?
3 hours ago, Rekin said:
I bet you are one of the drunks stumbling from the station back home. :P
nah m9 I usually just drive from the station
Edited by UNR33L
yeah there were 2x weird places near my old place. they were both off/on northrd near huntingdale station. Strange spots for them, really. woulda though dandy south/pound rd would have been much cheaper rent and ideal location for truckies.
on pound road - talk about good advertising
  • Like 1
Birds, my legs/quads are super stiff from training yesterday, but im keen to train again tonight. Will be a lot less leg work tonight, but dont want to look like an old man who struggles to stand up.
What can i do?
What can i do?
Eat more protein & calories, warm up & stretch the best you can before tonights workout oh and drink water
Edited by UNR33L
What can i do?
What Leigh said or pick up some of this from a supplement store
Light stretching helps with doms, as does eating enough protein for healing
Don't work the same muscles tonight unless you're on roids or a professional as it's pretty pointless for gains as they are already damaged, however some people find working the muscles lightly with empty bar or bodyweight helps with doms
Did some stretching at motel afterwork... Could barely get up after. Gave tonight a miss.
I smash water all day erryday, but learnt on monday that drinking too much before/after/during excercise does not go down well.
40 minutes ago, joeyjoejoejuniorshabadoo said:
why do those supps always have to come in such HUGE containers?
If you wanna get HUGE you gotta buy HUGE bro
I found a handful of decent new laptops for work to replace my current old one, sent links to boss... his response was we should buy a dell, so we can use their docking station because it has a 25-pin printer port on it. Because occasionally I come across units that need a text file to be sent via LPT port (which cant be simulated). (my current laptop cant do this, so i just ask others to do it)
So annoying. I dont want to be stuck with a Dell POS for the next 3 years. They stick the latest gen processors with outdated, homebrand components. Theres a sea of bad reviews, but theyre mixed with OK ones from 6 months ago before latest win10 updates. And we're not even going to be running win10! But dell dont laptops without software.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
