2 hours ago, Daz said:
Birds 88e cap raise?
You still in?
Yeah I missed opportunity to dodge that a day or two ago...
It'll open down, prolly fall to the cap raise price then we'll recover as per usual. Not a big deal for me as I'm long term, but would have been nice to pick up more shares for cheaper.
  • Like 1
So jetstar do japan domestic flights apparently... If i had of known that before i booked my qantas ticket i would have taken the bullet train instead.
Then becoz of usual 2hour jetstar delay, qantas changed my entire itinerary for some unknown reason. Instead of direct to melb from Narita, had to go via brisbane. So 2x stopovers requiring switching from domestic to international and having to sprint to each flight due to delays.... Arrive in melb 5 hours after original expected time. Miss my lift so now skybus + train + drive. F**k jetstar and f**k flying. Ill just jetski to japan next time.
I had a similar one years back, QF ticket turned out was code share on Vietnam Airlines.
Worst flight I had,
3 seats across center row, myself on aisle lady on far side and her 2 kids sharing center seat..1 vomiting milk on take off was a bad sign
Think 1/2 the people on the flight had shopped at the Queen vic market 3 hours prior to take off and brought on carry on...lots of aromas.
hour into flight some-one blocked the smoke detector in the toilet in front of me to use as the communal smoking room for the whole plane.
add in some disgusting airline food
the aroma by the end of the flight was horrific
Changed travel agent after that one.
I have learnt to check all flights that I get quoted now.
Off the plan are stamp duty free anyway IIRC, so the stamp duty exemption will only really assist new home buyers looking at established properties, in which case they will miss out on the FHOG because IIRC that has to be a new dwelling.
Will probably drive up demand a little bit once it sets in, but my logic is that in the interim there could be some cheap (<450k) established home bargains to be had as first home buyers wait until July 1 to purchase.
buy now with 120 day settlement and still get it
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
