18 hours ago, Odium said:
Got your entry to Broadford Greg. Will see you up there. You going to come and say Hi this time or not?
17 hours ago, Birds said:
He said hi to me last time, but I think that was only because I walked past him as he was fixing his car...
There's a lot of mental processing reserved for exploding cars that don't drive right and being a complete noob driver you know!
Finally got a friend's old beamer going and he also signed up for SAU. This is the guy that was fixing my car at Sandown while I was blabbing to Birds. His rationale for joining SAU was "Well unlike the BMW club they are at the track, and also I've fixed enough Skylines to be an honorary member even if they don't know it yet"
2 hours ago, Down_Shift said:
Lost 3-4kg in the past 3weeks... not sure if fat or body mass.
Thought I would be gaining whilst jobless.
that just means you're eating too much at work, maybe you're a heavy snacker?
or maybe you walking around more now?
Edited by UNR33L
So drove the S14 back home to the country today.
I really forgot just how bad the highway done/pot hole wrecking the back was.
that said the few sweeping bends went though made me remember why I did what I did.
I see a trailer in my not too distant future.  and many more track days
54 minutes ago, emts said:
is that one of the chinese ones with the phone home with full data on it?
I'm not sure what you mean.... but yeah, Chinese phones taking over yo. My HTC is over 2 years old now and app updates have just made it a slug for running most things. Reverted back to factory default for what apps I could and they run much better. Don't think its worth spending much on a phone if constant updates render everything redundant in a short span, a la Apple.
Considered the Nokia 3310, and it looks like the good ol' days of functionality but really need SOME basic internet stuff.
https://www.theregister.co.uk/2016/11/15/android_phoning_home_to_china/
TLDR
apparently a bunch of Chinese phone companies have firmware that monitors all traffic on the device and sends home
meant to be for mainland only but "accidentally" put on international ones as well.
Meh, if they want to monitor my sending of memes and organising car or family meets, then they're more than welcome to. The socialist party council can add me on Facebook for all I care. Need those instagrum followers
  • Like 1
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
