yeah they do an estimate based on previous usage every 3 months, only do a real check every 12 months or so and then do a top up.
I had the opposite in the past when I started traveling for work, usage dropped massively and ended up with a decent credit.
2 hours ago, HEKT1K said:
Went to a travel agent for the first time today, to see if I was missing out on the best deals etc
Travel agent: "Where's Skopje?"
nope
And when you been waiting and do a follow up with them forgetting to call you back with their deals.... "I forgot"
Just got a gas bill more than 3x of any bill in the last 12months, the charges go all the way to step-3 off peak.
Only gas appliances are heater and hot water. Heater is disconnected electrically and was serviced in winter. I was away from home 4 nights a week from Jan to Feb, then overseas for a month.
I'm reading that sometimes gas companies to 'catch-up' bills if they get their estimation wrong?
I'll check the gas meter when I get home, but if the figures are similar, ain't shit I can do?
Went from 27MJ a day to 147MJ a day. No leaks that I know of...
Old man had the same issue where his bill tripled in one month. He just didn't pay it until they came out and did a reading. Turns out they got their measurement units confused and over calculated it.
36 minutes ago, Mohsen said:
also how the f**k do i set up boost Ts?
you need a boost gauge.
cut your actuator vacc line in half. put boost tee on eitherside of cut vacc line. Set to like 1-2 turns off lowest setting. drive. note down boost. adjust accordingly.
44 minutes ago, Mohsen said:
boys boys boys.
whos got a metal intake pipe to suit rb25 laying around? trying to get the stag to rip massive VL spec doses lmao
Got one here if you want to buy.
3 hours ago, Mohsen said:
boys boys boys.
does anyone in this forum have anything to do with cars these days?
its only you and hamo who dont do cars no more.
I commented on something on facebook and the notorious Krysztof got butthurt. Am I getting him confused with that guy that is a living punchline in VWL?
done. 30psi TONIGHT
the question is, will it flutter like central park does if you walk through it with some bread?
how much. will pay top dollar for something dodgy as f**k.
a few of us still do, but it feels like were all in exile.
maybe one day we will unite and power will be restored.
  • Like 1
4 hours ago, Mohsen said:
boys boys boys.
Use K&H bumper black spray (the one for 80's black bumpers) and it looks like a stock part works a treat
  • Like 1
I might when the Kia Stinger GT is released as that think will need maybe exhaust/boost/tune
totally getting me one
yeah i saw some photos of them they look pretty decent actually
im thinking of upgrading but then i feel its a waste of money so meh.. probably gonna end up buying something lol
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
