34 minutes ago, Mohsen said:
the question is, will it flutter like central park does if you walk through it with some bread?
how much. will pay top dollar for something dodgy as f**k.
$80 and a reach around to make you flutter like a little girl tonight.
yeah, I'm not prepared to novate over 3 years due to the massive baloon and I'm not prepared to have a decent euro (not including the train tation hack golf I currently have before anyone points this out) non under warranty
yeah agree no warranty wouldnt touch a euro. Biggest mistake people make is buying a second hand euro which has depreciated a heap but they forget the repairs / maintenance / parts are priced according to original price..
Edited by alr33x
* and designed to fail
I've always been pro Aussie, but after driving a brand new Territory with interior ergonomics and design that hasn't changed since the 00s and buttons that feel like they were supplied by Fisher Price, I'd be steering clear of a Ford at least.
Actually, even new Subaru Foresters feel junky as f**k. Maybe new cars on the whole are sucking a dick.
I like to live dangerously
  • Like 1
Yeah they're still based on the 08 FG, same as my 2011 although mines got some FPV adjustments & improvements.
I still rate mine better than the 2015 STI I drove in almost all areas beside the seat / satnav. Camera + climate control of the Ford shat on the STI
Oh the STI had a nicer steering wheel too.. felt like a Prius power wise though, WRX > STI engine
Edited by UNR33L
you need a boost gauge.
cut your actuator vacc line in half. put boost tee on eitherside of cut vacc line. Set to like 1-2 turns off lowest setting. drive. note down boost. adjust accordingly.
Who gives legitimately useful advice in a wasteland thread.
Wtf man.
  • Like 2
My ford's interior all feels pretty nice.
It's a euro built one though. Most of the Aussie ones are built in Thailand where a fewer number of f**ks are given to quality as long as it's cheap.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
