34 minutes ago, Mohsen said:
the question is, will it flutter like central park does if you walk through it with some bread?
how much. will pay top dollar for something dodgy as f**k.
$80 and a reach around to make you flutter like a little girl tonight.
yeah, I'm not prepared to novate over 3 years due to the massive baloon and I'm not prepared to have a decent euro (not including the train tation hack golf I currently have before anyone points this out) non under warranty
yeah agree no warranty wouldnt touch a euro. Biggest mistake people make is buying a second hand euro which has depreciated a heap but they forget the repairs / maintenance / parts are priced according to original price..
Edited by alr33x
* and designed to fail
I've always been pro Aussie, but after driving a brand new Territory with interior ergonomics and design that hasn't changed since the 00s and buttons that feel like they were supplied by Fisher Price, I'd be steering clear of a Ford at least.
Actually, even new Subaru Foresters feel junky as f**k. Maybe new cars on the whole are sucking a dick.
I like to live dangerously
  • Like 1
Yeah they're still based on the 08 FG, same as my 2011 although mines got some FPV adjustments & improvements.
I still rate mine better than the 2015 STI I drove in almost all areas beside the seat / satnav. Camera + climate control of the Ford shat on the STI
Oh the STI had a nicer steering wheel too.. felt like a Prius power wise though, WRX > STI engine
Edited by UNR33L
you need a boost gauge.
cut your actuator vacc line in half. put boost tee on eitherside of cut vacc line. Set to like 1-2 turns off lowest setting. drive. note down boost. adjust accordingly.
Who gives legitimately useful advice in a wasteland thread.
Wtf man.
  • Like 2
My ford's interior all feels pretty nice.
It's a euro built one though. Most of the Aussie ones are built in Thailand where a fewer number of f**ks are given to quality as long as it's cheap.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
