I got nothing but praise for Internodes customer service and billing/sales. Now that i have an NBN box installed i would switch back to them in a heartbeat
Though guy at work is trying to convince me MyRepublic's $60 high speed NBn unlimited plan is the way to go
I wouldn't touch Myrepublic, sure if it works great.. if you ever have any problems good luck actually speaking to anybody or EVER getting a callback
Dont say i didnt warn ya :D
Edited by UNR33L
Please let me show you how to use the application YOU use everyday and that IVE never seen before.. sure..
But you are I.T Tech? Fix my microwave & TV plox.
Edited by UNR33L
OMG got onto a telstra tech that know's what he's talking about :O
How good is it.
I got out through to Australian tech support once I asked for the complaints department... I'll remember that for next time.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
