*sigh*.... I think I'm going to buy an XR6 Turbo :/ Bang for buck on an FG MkII is just too good to pass up compared to everything else in my criteria.
Post-2010, newer the better
Over 200kw
Under $30k
No Out of Warranty Euros
It's either Commodore or Falcon, and the towing capacity on the falcon wins out. Pity the interior is a bit basic.
*sigh*.... I think I'm going to buy an XR6 Turbo [emoji32] Bang for buck on an FG MkII is just too good to pass up compared to everything else in my criteria.
Over 200kw
Under $30k
With a few small mods it's good for an easy 350kw, let alone 200kw
XR6T has the same interior if you get the leather option (like mine) just make sure you get one with "premium sound" and "colour screen", reverse camera even better (like mine)
Leather, colour screen, premium sound (subwoofer), reverse camera are the options you want. Then the interior won't seem as cheap.
If you get a 2012 or newer it'll be mark 2 with a touch screen and different headlights + front bar , and they're all colour so slightly better oh and they have bluetooth music streaming, unlike mark 1 which has ipod connection + aux. (still bluetooth for phone CALLS though)
the xr6t engine makes around 250rwkw ish stock anyways, tune it with injectors, new dump + cat, intake and you see some pretty good gains
oh and yeh, they tow like you've got nothing on the back.. awesome towing cars. #fordsalesrep
Edited by UNR33L
i hope you wrote that with a VB in your hand....
  • Like 1
I wish.. cup of tea
Nothing like chopping cars with a trailer on the back, dat extra grip. Although scared I'm gonna rip the back of my car off sometimes so don't launch it, just on rolls
Edited by UNR33L
Pretty sure the G6E T has the same engine and gearbox, but no LSD and softer suspension?
2300kg is an impressive tow weight, compared to 1600 for most commodores unless you get a wagon and calais
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
