1 hour ago, Leroy Peterson said:
I'm getting spud mixed up with other things...
actual informative post about the drilling plan (but not actually related to results or value or anything): https://hotcopper.com.au/threads/ann-operations-commence-at-icewine-2.3312384/page-32?post_id=23523786#.WOMZ7LgQ_IU
4.5
$600 in profit today...damn you temptation.
12 minutes ago, UNR33L said:
Take own advice and hold off :P
$870 profit now on close
Yeah I'm holding off. This well is the make or break for 88E IMO. Still think it will sink post spud like last drill, but not worth the risk that it may not.
what date? ill sell the day after lol
4 hours ago, UNR33L said:
in typical 88e fashion, straight back down after a good day :P
You had your opportunity to short trade it...
Can actually blame London for this one. They didn't continue with our optimism. Someone bought up big in Aus and we carried on...spec shareholders are incredibly knee jerky for people who are supposed to be investing long term...
I'm wondering where V-spec performance get the money/capital to buy some of the most expensive GTRs that pop up for sale. I'm not too cluey on how supercar used car dealerships run, but when starting from the ground up it must be a massive uphill battle until properly established.
Looks like they almost have more cars for sale than they've sold since opening. I wonder if someone is fronting the cash as like an investment or buying overseas then giving it to the dealer to sell, dealer sells the car (eventually), both original buyer and dealership make money. The one getting pinged is the customer since theyre paying exorbitant prices for cars that sometimes dont have an accurate expected value.
https://www.vspecperformance.com.au/temp2
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
