On 5/5/2017 at 11:22 PM, emts said:
any-one play with drone photography here?
got pointers for a beginner?
I got a mavic pro recently, only taken it for a few flys so far.. my tip is slow and steady, I don't just go guns blazing 5km away.. like to keep it in sight while I'm noob
grabbed a Phantom 3 Pro with a bunch of upgrades dirt cheap from a guy at work as he upgraded,
just so long as I don't crash it first time out it all good.
figure go super slow to start with and just have some fun.
one got it worked out can use to check seating on the deck at the lock pub to see if it worth going.
The flying part I find easy, its the trying to spot any power lines etc through the phone screen once you fly far enough away to be out of sight.
Good fun and gets some great shots, I can see it being one of these things I use for like a year then sell it though, would make awesome holiday video if travelling.
Edited by UNR33L
Anyone wanna buy my 2014 WR450F? $7900 thx
Actually just putting bikesales ad up now.. $75 now to list! pretty sure it used to be like $50
Unfortunately it's the only decent place to sell stuff.. Facebook is full of dream boats
Edited by UNR33L
15 minutes ago, emts said:
but my mate bought one for 5400  in better condition,,so yeah say 4000, or swaps for a half eaten sandwich and a troll doll? k thx
Sure I will provide you my acc details
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
