33 minutes ago, TiTAN said:
Friend has an unlimited Amazon cloud storage account (think it's $60 a year) hooked up to his synology 12 Bay nas.
Took a while but the whole things replicated to Amazon in case something goes wrong/stolen etc.
It's a great solution to hook your nas up to cloud storage for offsite and some will roll back changes if you get ransomware for example, any change after x time is just wiped out and you download it from them, have done this with Dropbox before.
Beauty of slow aussie uploads means if you get ransomware it'll take ages to replicate anyway haha
12 minutes ago, dezz said:
Could probably find some spare cloud space where I work...
Typically you can link up your NAS to dropbox,onedrive,google drive (just google your model and what you can do with it) most offer a few hundred gig free anyway which is fine for your typical backup of important holiday pictures, documents etc.
Something to try and work out if you get the chance and can be f**ked
Otherwise yeah like you've been doing copy stuff to it from your laptop so you've got it in 2 locations, the disadvantage of that is if you get robbed or house burns down all your data gone.
Edited by UNR33L
Ordered an ebay 2000w generator for tyre warmers @ the track Michael - seeing as you're a sparky, am I gonna die using it?
http://www.ebay.com.au/itm/122413496619?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Don't get me wrong would of loved a Honda or Yamaha one.. but they're like $2k
I'm more interested in where you're doing track days that don't have power available..
I got you wrong
Hope you got a warranty
you see some many of these abandoned after Bathurst as didn't make it through the weekend
plus super noisy and forget 2000watts. Maybe a quick peak but yeah serious draw will kill them
reason the yam/Honda cost more
Murray Valley, Broadford (race days where you need to pay for garage or limited availability), South Morang Gokart track etc.
Edited by UNR33L
Yeah one year warranty, she'll be right looked at some reviews. The warmers will only draw about 1000watts this thing is rated for 1700 running.
Bathurst probably full of drunk people overloading them I guess? Mate of mine got an Aldi one and still going strong
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
