3 hours ago, Daz said:
Need a ser 3 as apparently they are different
http://www.wiringspecialties.com/unrbwihatupr.html
Can confirm with these guys if they're different, but I'm pretty sure they're the same as it's the exact same engine with no extra sensors.
f**k 88e
My counterstrike skin has gone up in value $100USD since last week
Appears to be a bit of a price fixing - someone bought up all the case hardened stat trak karambits and relisted them for thousands of dollars, so genuine sellers have listed theirs for much less but still more than they were a week or so ago. Good times.
I can't believe people pay good money for that shit. And it's the gayest looking knife ever.
Even though I was watching the ESL matches last week in Sydney and made money live betting the rounds....
51 minutes ago, UNR33L said:
Shit knife m8
Skins don't get da kills
Skins get the money and if scarface has taught me anything, you'll soon find yourself the women
I never watched it all the way through though, so I assume happy endings for all
I used to think so too, but, since I'm making money off them, I say let them spend their Christmas money
I actually like the look of that one, but it's rarity that decides the value
Don't know how the whole skin economy hasn't been shut down yet by underage gambling laws, it's as pure as gambling gets
valve pls.
It was brought up in Europe I think.
5 minutes ago, dezz said:
Should you get the original windows CD when you buy a new laptop / computer with Windows installed?
not any more.
shit 3 laptops in our house not one has CD/DVD so would not be usefull.
should have a Certificate sticker on it and a copy of the installer on the drive.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
