7 hours ago, TiTAN said:
So a massive gate and massive sliding/folding glass doors across the whole back of the place?
It seems like a fine stage from which to show off your efforts in the gym, at least thats the first reason you would want it that comes to mind.
24 minutes ago, emts said:
small side garden I see to work on.
the empty lot next door is that part of the park or will some-one build on it?
Park - only have one neighbour.
first home buyers duty reduction. you get 50% off if it your primary place of residence.
if you put the full 80% down them you don;t need to pay loan mortgage insurance.
simples
You mean 20%
If you put down 80% up front on your first house you have done well.
Going 20% deposit also gets you lower interest rates on top of not having to pay mortgage insurance.
3 minutes ago, TiTAN said:
You mean 20%
With this I got the NAB first home buyer rate which is apparently the best in the market right now - fixed for two years. Also get about $1800 worth of shopping vouchers.
Oh shiiiit
Don't tell him/her that you earned the money with CSGO skins
I prefer independent jewellers (bcoz hipster) because the people and artists actually know what they're doing, and they have no reason to lie to you, the items do all the talking so to speak. It's not just a spec sheet.
I've used e.g. etal in the CBD a couple of times. More designer stuff, but guaranteed unique and brownie points for the wimminz (compliments and envy galore amongst peers). Also got quality custom necklace from Ralf Finch in The Basin (chose a design, picked necklace and got to choose the pearls to use).
Edit: diamond earrings is a tough choice. Easily lost, small, mostly are studs so super subtle.
3 minutes ago, Leroy Peterson said:
Oh shiiiit
I've used e.g. etal in the CBD a couple of times. More designer stuff, but guaranteed unique and brownie points for the wimminz (compliments and envy galore amongst peers). Also got quality custom earrings from Ralf Finch in The Basin (chose a design, picked necklace and got to choose the pearls to use).
"Pearl necklace" sure sure
Ok cool so there's no decent online shop gotta get off my ass and go somewhere?
Mortgage insurance is proportional to your LVR and there's a law of diminishing returns to it, which starts to get awfully shitty when borrowing at high LVRs.
Here's a good example - you have 70k saved up as a first home buyer, it could be allocated as such:
A. 600k property, 5% deposit of 30k, LMI of 26k, stamp duty 15k = initial upfront of ~70k and your LVR is 95% on 570k borrowed
B. 500k property, 10% deposit of 50k, LMI of 9k, stamp duty 11k = initial upfront of ~71k and your LVR is 90% on 450k borrowed
So whilst 100k difference between the purchase price of the two places, the more expensive one actually requires you to borrow 120k more due to money spent on LMI (and some for the extra stamp duty).
One loophole you could use to avoid this - get a relative to borrow and "gift" you enough to make up a 20% deposit and cover the stamp duty - you finance the other 80% = no mortgage insurance and you just service both loans. Or they can go guarantor on the loan and you technically don't need any deposit or LMI.
I'm on 3.81% at the moment, zero annual fees.
Looks like the comparison rate for that 3.69% deal is 4.38%
Pretty sure ubank and loans.com.au are still the actual comparable cheapest as they have no annual fees on their variable rate loans, with a once off few hundred $$ fee if you want to go fixed rate. But you have to have minimum 20% deposit to get those deals.
1 hour ago, UNR33L said:
Where's a good place to buy some diamond earrings?
Don't mind spending a bit but not stupid amounts, birthday present.
Inb4 subtle, VWL6fig, 800k etc.
http://www.bbc.com/news/world-europe-39943470
48 minutes ago, TiTAN said:
Il stick with my pay less interest and fees In the long run than get some vouchers up front plan.
We comparing our loans or what was available to me at the time?
It was available to you too? You said you went in on 20% or more deposit?
Talking about the rate; I have no idea when you obtained a loan.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
