9 hours ago, Birds said:
On the open wheeler note
https://www.carsales.com.au/private/details/Ariel-Atom-2004/SSE-AD-3899997
Why on earth would you need that much power...sounds awfully close to F1 kw/kg territory
no mention on the fact the chassis was cut up and rewelded to new dimensions to pass au kit car rules.
or the fact I don;t think it has finished a track day without blowing something up.
have seen in the pits a few times years back and closer it gets the scarier it gets...
Dezz when you are installing windows 10 make sure you delete all your existing partitions on your hard drive, then create a new partition for the full size (it'll be empty) then install on that.
(Probably self explanatory & do it anyway just checking you're doing it right and not installing over the top or 'upgradeing')
It's a lot of money for an experience... And that's about it.
Again, would go for a Caterham. At least they are proper registerable and the duratec/zetec motors are known quantities with info and spares.
Probably wouldn't have done what you just said actually... Left it downloading over night and didn't check it before work this morning.. Can I still do the partition now or do I need to start again? Laptop was wiped and windows 8 reinstalled, I've only put shit like utorrent and ipvanish on it so far..
Would give a 620r a solid go.
It will wipe what ever is on the hard drive currently, so you boot from windows 10 usb stick > install windows > custom / advanced > you'll see your hard disk and it's partitions, delete them all so it's empty, unformatted, then click new > accept the default size (it'll be max hdd size > click on your new partition > install > wait 30 mins > done
You now have fresh windows 10 install with no other crap left over from windows 8 etc. Laptop will be faster, better stronger.
There'll be a youtube video somewhere of it surely, but my instructions should be good enough
Edited by UNR33L
f**k lots of steps involved.. Think I just upgraded when I first went to 10.. But laptop is pretty much empty at the moment so I guess I'll do it... I think the os is automatically installed on the SSD and the sata drive is just for everything else and porn...
I'll read your instructions when I'm at home and not balancing on the edge of a switchboard.
It's pretty easy, and it's worth while doing a 'fresh' install over just an upgrade.
Yeah install OS on the SSD ofcourse, you can add/format the Sata drive in later for your porn in windows disk manager
Edited by UNR33L
If I do this partition shit will I still be able to install 10? Was under the impression it scanned your computer for a legit windows licence before letting you update to 10.. If I've formatted completely, won't I lose that?
Nah it still works, key is embedded in the hardware
13 hours ago, blah_blah said:
Can confirm Gregs car is an absolute beast. id be surprised if any rwd skyline on here could beat it from.a dig. Birds pls respond
You just can't climb in the ring with Ali cause you think you box
  • Like 1
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
