These landscape gardener kunce quoting my joint make the trade unions look like far left wing liberal f**ktards as far as pay rates go. Wouldn't mind some of whatever drugs they're on..
My backyard... Around $2k in materials, say $2500 just to highlight the ridiculousness of what they want for labour... First official quote was $5k. Dreaming. Second quote was from a description only, $3-6k, but the third quote, which is my favourite........... $9000
Have to call to confirm that the price includes taking the virginity of his 3 centrefold daughters.
Seriously these kunce are off their heads. It's not even technical work. If I can do it myself, you can't ask for $1500 a day labour, for a job that would take 2 days tops, with a straight face.
And $1500 a day is the $5k quote obviously... Not sure where the $9k mother f**ker gets his 24ct gold timber from...
Clearly you mine that timber out of the ground and it requires a lot of processing like any minerals you dig up.
That he can clad your garden in that at such a low price and so quickly is amazing in and of itself.
tradies are f**ked ay
  • Like 3
Under a union, they wouldn't be able to demand such ridiculous money.
Construction industry is still profitable... Because at the end of the day everyone needs to make money. Except the buyers.
Or essential services need to keep running, because they're essential. And people have no choice but to pay it.
But no one gives a f**k about your garden.
I had a similar experience albeit of a far lower value.
Had a broken pipe in the front yard from a tree root... I dug out the pipe and removed the root, plumber came round cut out a bit of the pipe and attached some sort of joinmatron device... 5 mins work... $300
pipe broke again on the weekend (different spot, same reason) so I went to bunnings and bought the part... did it myself in apprx 5 mins
$7
fuckin tradies
  • Like 1
At the moment the people who appear to me to be ripping off the most are specialists in the medical profession.
First visit literally a 5 minute consultation with a few background questions that could have been answered by me filling out a form = $250. Even with $150 paid by Medicare that's extortion of the highest order.
Y'all here complaining about $300 for someone to drive to your house, use materials, fix something and then drive off. But at the same time people here have been discussing hourly charge out rates for IT staff to sit at their desk and take 3 piss breaks an hour for $270+
If it cost $300 to see how easy a job is and what materials to use, so you can DIY it in future... Maybe it's not so bad.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
