It's an mx5...
But with turbo.
And it wouldn't be for me. Be for gf I don't have yet. So I can drive it occasionally but also say "dw fellas, it's not mine m8"
I keep forgetting about flash tunes... Need dat stage 1.5
1 hour ago, Leroy Peterson said:
I like my ECUs like my women... Only programmable via unicode
Expensive, too many add on modules and only specialists know how to modify behaviour
The fiata 124 sounds great (!!) and yeah has a turbo. Same motor that the old Fiat 500 abarth has (which also sounds amazeballs and not too bad to get to 220kw)
Which is more than enough in a 950kg car made for fun.
Souce: Skyline owner who wishes he had his gf's MX5 all the time.
  • Like 1
Guy seems to have trouble keeping grip under throttle...not sure if it's damp or just a tail-happy lightweight car
Sounds alright but you'd be pushing that 1.4 hard to get it where you want it performance wise...I'm talking a hypergear high flow....Nismo 555s...PFC...Z32...GTR intake mod...
  • Like 1
6 minutes ago, joeyjoejoejuniorshabadoo said:
MX5's are freaking amazing when done well. I kinda want an SE
With the prices they are asking I'd rather SR20 a standard one...you know...just drop one in cause that's how easy engine conversions are
  • Like 1
If Mazda had given the latest MX5 the balls to pull a 5.5 second 0-100 it would have smashed the 86 for sales
In other small targa/convertible options...
I see Alfa 4Cs are still commanding huge prices
Lotus' seem like good second hand value if you consider the depreciation from new
And last of the MR2s converted to the last Celica engine look like fun
Have you seen project thunderbolt on YouTube? Guy takes an mx5 and a flying miata kit and drops a 6L 370kw LS crate motor into it and to a standard where it's passable for a "that's how it came from the factory" appearance.
Why would you go a Lexus motor? Clearly an LS would have made as much or more power with far greater ease. Also, it has an r154 "supra gearbox".
The more you read the spec sheet the more you are wondering wtf the builder was thinking when making those choices.
I've seen them make a few appearances...something different and probably nicer to drive. The only thing that doesn't make sense to me in the build is a Porsche fuel pump.
Where did it say/show it had an R154? They did come in 1JZ Supras. Great box but I wouldn't want to break it with how rare and expensive they are now.
Edit: just saw you can buy them brand new on eBay from Toyota for 3k? Daduq? When did this happen!
Just looked it up...does look nice and factory. Wonder if the LS upset the handling at all...apparently doesn't bother the RX7s too much. That's probably something I'd say excessive / tyre frying. Be happy with about 200rwkw in an MX5; would be plenty to have fun and keep it tractable on the street.
It says 5 speed supra box. The getrag boxes from the mk4 are 6 speed, so it has to be the r154 from the mk3.
Porsche fuel pump probably just means it's an 044.
Freind of mine came by the other night to give me a lift somewhere... showed up in his new daily.
2002 BMW 745li with the v8
Was $245,000 with the options on his, now $10,000
Going to be fun once something breaks
Nah most 5 speed Supras came with a W58. They only used R154 in the MK3 to handle 1JZ no shit + in Soarers and Chasers. Originally a JDM Hilux 2WD box, which explains why they have a horribly agricultural shift feel.
W58/57/55 boxes are the most common Supra boxes found in conversions cause they are small, relatively strong, have a range of shifter housing lengths (including remote), and were plentiful before all the kit car and 70s Holden/Ford manual conversion guys pillaged them from wreckers.
The R154 is slightly larger but still a small box considering the power it holds. Used to upsell people to it when they asked for a W58 box to put behind a decent V8. Not many Aussie converters knew about them, but they also used to be rare cause the JDM / Supra guys would snap them up for their own conversions. Obviously not a problem now you can buy brand new lol. So there's a chance it could still be an R154 in there, particularly when he's done a Toyota V8 conversion and adaptor plates were/are available on eBay. Strong box but the GTS-T one is much nicer to shift.
Buy another one for parts lol
VIP that shit. Our VIP group needs some euro.
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
