On the subject of e-bikes.
Surely they're expensive as everyone first looked, although there's a couple of benefits - no licence and registration is needed until the government decides it is needed which won't happen I reckon as it's still a "bicycle"
No license, insurance or fuel/maintenance costs. Although $4k upfront I wouldn't think there would be much running costs after this. Just plug & play.
So finished moving house over the last 2 weekends.. f**k doing that again for a while!!
Hired a truck for the big main shit in the end, man those things are stressful to drive with the height, visibility etc. was close to taking out the gutters on my house didn't realise it was so tall. They are also SLOW AF flat foot and you barely make lights and normal cars pull away lel.
Ebike vs motorbike the decision is simple, if you are just using it for work commute <10km without freeways / high speed needed then Ebike all the way. Motorbike if high speed and you plan on riding through the hills on the weekends and making a hobby out of it & joining the community. Don't forget 1k at least for semi decent gear.
Edited by UNR33L
Yep, upfront costs are quite high, same with current corp of electric cars.
It'll get cheaper over time or if you're prepared to go s/hand.
  • Like 1
Should have paid someone to carry your shit and drive them.
meh was only like $200 for the day which I would of spent moving the little stuff too anyway
new crib is in Vermont, Birds move back home so we can hang brah.
Renting, don't wanna know how much I'm paying.. lel. Also 6 weeks bond (because new) was robbery.
Yeah it's pretty nice, horses and shit 100 meters down the road good little pocket near boronia road / eastlink & good bush to walk the dog. Basically a 3 bedroom new townhouse.
We would need 2 episodes for Dezz's house amiright
One of the main reasons of moving, dat dere double garage:
22553578_10154963435073779_1303904973_o.
Edited by UNR33L
Why V-town? Pretty close to your folks now. You can go yabbying in the dell. Will swing past next time I visit the olds.
Loving my freeway access in the south east though. Aaron/Sunkist and I just realised we live 2-3 mins from each other  now - car working bees coming right up.
I thought my double was small - is that a 5.5 x 6 and your car just takes up a shitload of it?
Eastlink?
Yeah really close to your folks let me know when you are around, we chose V-town because closer to work basically & near the freeway.
Nah it's actually a pretty decent size it's just my car is parked way over in the middle of it so doesn't look it. there's a fair bit of space in front of my car with a work bench too, my cars 5 meters long don't forget (nohomo)
That photo is basically taken from the kitchen.
Edited by UNR33L
11 minutes ago, TiTAN said:
I like Finnegan from roadkills garage, the whole bottom level of his house is garage/workshop/storage space. Would be hard to get that approved by the council though I would think.
Dad got a pit built into his garage when they built their place in 1990 still works awesome for low cars / oil changes etc
58 minutes ago, TiTAN said:
Eastlink?
Monash and the south gippy, but not far from eastlink either.
Basically I can get anywhere reasonably quickly. Except the city. But on a good traffic day that would still be only ~40 mins.
Protip for garage kitchen access...get a storage tub from bunnings and put it just inside the garage near kitchen door. So handy to throw bottles/cardboard/paper/fingernails into.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
