2 hours ago, Leroy Peterson said:
Seems pretty standard. On my watch list. CPH did the same thing when it listed, then went below initial price over the course of a month, could be similar here being so pricey for pharma.
If it were guaranteed everyone would jump on IPOs. I've seen some terrible floats!
Wish I'd bought, knew the new CEO was going to try and win people over... The money from Indonesia was a deposit for hardware, not their tech, and still no mention of an amount or total amount owed.
Brazilian thing seems OK, but who wants to pay a subscription to watch free to air on their phone? At least, that's what it sounds like
Huge increase since float, I wonder how long it'll last - they seem to be flooding the announcements, feels less like progress and more like trickling news of things already being worked on to artificially boost?
On 22/11/2017 at 7:19 PM, joeyjoejoejuniorshabadoo said:
Technically that's only 1.4% of what is statistically proven to be real money
I'm impresses you actually took the time to work that out
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
