Vic Wasteland Thread - 15.0
R31Nismoid
 Share
Copped a puncture on the monash Friday
Old Federal RSRR were nearly bald so, with the need to get back on the road asap, thought I'd give the RE003 a go in 245/40 all round. Impressive all round tyre for the money - $840 for four with an alignment.
They don't grip quite as well as I remember the Federals did when new, but it's expected with a treadwear of 200-220. Much much less road noise and look actually useful in the wet. Love the confidence that new tyres inspire in driving feel!
Coinspot doing AUD to crypto, but 7% transaction fees... And I can't even send my coins to another wallet due to some glitch.
Don't recommend.
Blockfolio app is now indispensable. Helps keep track of shit as watching stuff on Bittrex is annoying and only keeps transaction history for a month, pretty shitty really.
I'm leaning towards the re-71r (don't expect more than 10k out of them). Most normal tyre shops can get them but won't stock them and they seem to be only a little more than the re003. Gordon leven in Sydney seem to keep the common sizes in stock (they only do motor sport tyres) tyres shops have referred me to them before as apparently they get priority over jax/Bob Jane etc on the high grip/short life tyres if you need sizes that aren't commonly brought into the country in qty.
Don't recommend.
What's the alternative ive signed up with BTC markets and also Coinspot for alts.
There are many
Binance is cheap but doesn't have everything, Bittrex also good
10 hours ago, Kinkstaah said:
Where were they from?
Did think about going Bridgestone or Michelin for dat Costco discount.
FYI though, RSRR in 255/40/17 are something like $700 fitted for 4.
Bob Jane 3+1 Christmas special
These were 245/40/18
255/40/17 is usually a pretty cheap fitment across most brands and I'm tipping $700 doesn't get you an alignment?
I nearly went with AD08Rs again but they didn't have in stock
Needed my car for this week so thought it better to bite the bullet on the best performance tyre they could give me and I have wanted to try these for a while. Curious about their wet weather performance and if I get more than 10k out of them with my driving style.
Nah no alignment. Wasn't my car either lol, dhf tyres in hallam if down that way.
Wasn't 3+1 however, one day I'll go to Costco and actually ask them to price match on re71r or PS4 or pilot sport cups, while I get fat on hotdogs there.
Coinbase is easy to use, but can be slow due to volume. Send btc or eth or Ltc from there to binance or Bittrex. Then happy shopping. Otherwise if you just want to go AUD-most coins, and vice versa use coinspot.
If you wanted to buy say 5 bitcoins for example, is it as easy as having one of these 'wallets' and the ~100k necessary to do so or is it difficult to buy whole coins due to limited availability?
I think something like 17,000 bitcoins worth get traded each day, not sure if 5 could be bought at the same price... But Coinbase, coinspot you have to "earn" your way to big amounts. Because it can be quite easy to do a dodgy on them with the way crypto works. So for example a mate and f mine been trading for over a year and his limit is 20,000pounds.
My Coinbase limit is $500 a week. Coinspot... I dunno, $5000?
I'm not sure if there's brokers around or something might be able to do big purchases. There'd have to be.
 Share
    • Embrace the freedom of casual encounters on the best dating app in town! Verified Maidens Superlative Сasual Dating
    • Slimline sub on the rear parcel shelf is doable. Pioneer TS-WX140DA is only 70mm high.
    • People like Johnny Dose Bro might be laughing at my post because I accidentally added 100mm to my numbers. 350-355 is indeed the lower limit. 450 is off-road Skyline spec.
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
    • Easiest way to know is to break out the multimeter and measure it when cold, then measure all the resistances again once it gets hot enough to misfire. Both the original ignitor and the J Replace version. Factory service manual will have the spec for the terminal measurements.
