Vic Wasteland Thread - 15.0
R31Nismoid
 Share
Whats finance rates like on a new car anyway? I paid cash cos VWL 2k17 800k baller club obviously
The mrs is looking for a new car and considering financing majority of it. Makes sense if the rates are shit all, gets you in the car sooner.
After 1 month of having a tenant move into my unit the hot water system starts leaking and needs replacement, garage gutter leaking into garage needs replacing fml LOL Costing me more than it's worth.
Negative gearing. Claim it against your vwlbc income.
Great deals will see 2% on a factory deals. most will do 5.5ish if you haggle over the rate. So the ultimate cost vs pulling money out of mortgage is ~1-2%
I used to think many cars on the road were owned, but when you consider how many are company or fleet and then the privately owned cars of which a big deal would be financed, there's probably very little actual cash in them.
Just trips me out when I talk to people about expenses and they mention their car payments. I've never had one under finance, probably never will because I thought it was uncommon practice, even though it isn't lol
I've been looking at loan %'s and repayments etc because the Mrs needs $20k in dental done and doesn't have the cash. All in all, the lender doesn't make a huge amount of money out of it... Like if I was giving someone $20k I'd want more back than that lol.
Generally if a car company is offering finance that is extraordinary low (i.e.) RBA cash rate low then they are making up the margin via other areas. I.e. Less of a discount on the purchase price of the car.
  • Like 1
Lisa needs braces
  • Like 2
Sometimes you gotta check the fine print... Like some dental is covered, some (and usually a lot) isn't.
She had a bridge done by someone and its lasted a bit over 2 years. New dentist/specialist saying to go back to the other guy and demand some of the money back... Does that actually work??
Now needs bridge redone plus more work, and basic extras health insurance doesn't cover major dental.
#rowvilletheplacetobe
Man, crypto trading is to Jackass what the ASX is to Bob Ross. It really is a new gold rush.
The fact that Coinbase newcomers can jack up the price on Litecoin and Ethereum just because bitcoin is taking Coinbase too long to process... It's insane.
Be wary...strong honeymoon quick divorce
 Share
    • This morning I carefully reinstalled the manifold and started looking at a couple of things I need to do.  Heat wrap arrived sometime today so I popped into the shed with the missus dishwashing gloves and started wrapping the first half of the dump and the screamer/plumb back.  Once I do the second half I'll be able to final fit the turbo and exhaust up.  Also pulled the harness out today and started terminating it at the ECU end. A connector is done, just need to run the remaining wires that arent in the harness - 12v, gnd and couple I/O
    • A31 is pretty much the same thing without HiAIDS I mean CAS, no improvement lol. Not to late to send it.
    • Thanks for all the replies! I also wanted to ask if wheels that were fitted on Ford Falcons would fit the 350GTs as well? In the area I'm at there aren't that many options for secondhand wheels and new ones here are way out of my budget. From what I've seen, most of the wheels that are available that were fitted on Ford Falcons have an offset of +33 to +36, with a centre bore of 70.5mm whereas the stock 350GT's ones are 66mm, can't seem to find any hubcentric rings that fit that difference though.
    • 215/45/18 tyres are probably a little on the low side compared to the factory tyre, it should be closer to a 245/45/19, which will get you about an extra 11mm of height, and should make you speedo read a bit closer to reality. 245/45/19s will be a bit too far the other way and you risk a speeding ticket as your speedo might read slower than your actual speed.  245/40/19s would be correct if you are going to 19in rims, they will give you a similar total diameter to the 245/45/18 tyres.
    • That's something I forgot to put in my list. The aggressive anti-squat in R32 is a f**king menace. I still need to decide if I'm going to drag the subframe out of my car and weld in the GKTech corrector kit. The main reason to dither is the need to switch to spherical joints in the lower arm to account for the twist induced in the rear pivot caused by lowering the front pivot. And yes...we do put better subframes in R32s, and I wish I'd gotten an S14 one instead of an A31 when I did the "take off and nuke it from orbit" HICAS delete all those years ago.
