21 minutes ago, Leroy Peterson said:
https://www.autotrader.com/cars-for-sale/vehicledetails.xhtml?listingId=487434773
Now THATs an investment. Signed by Pol Wolker himself. Owned by Frankie Muniz apparently....
It's actually a pretty cool looking car, if it had smaller wheels and more low
call fake....
the real one had invisible brake calipers
Image result for fast and furious jetta no brake calipers
some-one is trying to make a nice profit on it tho
https://carbuzz.com/news/the-fast-and-the-furious-jetta-just-sold-for-a-pathetically-low-amount
Yeah someone brought up the brakes thing.... Who da f**k knows.
I still don't get the supra thing.... I know the guy who bought Aarons old wide body shell. Gearbox and motor will set him back more than the the body and a full restoration will.
so the OEM brakes on it were too small so they put one of those fake big brake covers on it to hide the tiny ones.
some-one (smartly) removed it at some stage
so yeah it is the real car, it's just of all the cars in the show that prob the lease attractive to own, 2l NA auto....
https://www.ebay.com.au/itm/2x-Universal-Auto-Car-Wheel-Disc-Brake-Racing-Cover-Silver-Q9N7/183369226178?epid=23008171393&hash=item2ab1a857c2
At the time of the movie though, all the Leroy types were fawning over it cause the JDM was too mainstream
Safe to say a combination of rarity / collectable and those movies are responsible for JDM sky high prices. No surprise that the vehicles with the most gained from it are those featured as heroes in the movie...34R, Supra and RX-7. S2000 has also seen a good comeback on pricing. Then again, Jap classics like Hakosuka, RX3, VL Commodore and 2000GT did it just fine without movie power behind them.
  • Like 1
2 hours ago, emts said:
call fake....
Apparently S2000s are front wheel drive ?
I do agree with them about it being nicer back in the day when a dramatic scene didn't involve crossing buildings in a car and the excitement came from who would win a race and who was cutting who's tuna lunch
If the script was smart enough someone would have commented on the booty call but instead we got "burger and fires for 2.95"
Am I still a Leroy type? I stanced out the Gloria last weekend. Didn't even get many efames :(
Am I still a Leroy type? I stanced out the Gloria last weekend. Didn't even get many efames default_sad.png&key=60edf0cfeb1b5687d093da59e19dcb4bc4ca5078c255acb1c3a47ac6adc5cc5e
Not enough filter.
That’s why.
  • Like 2
Not enough filter.
That’s why.
The wraps only come in one size... So I guess anyone that doesn't like wraps and gets embarrassed ordering a footlong?
Speaking of footlong... Might try to get a massive weiner in me this weekend. Chapel St is shit, but I'll make the effort for a giant hotdog
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
