NNah it's the head gaskets, the RS has a coolant outlet that the Mustang does not so fluid was going in and not circulating..
https://jalopnik.com/did-ford-install-the-wrong-head-gaskets-on-the-focus-rs-1821665968
Went and inspected a Honda Jazz for the Mrs last night at 5pm. Said I was interested, just needed to discuss details with her etc. Emailed 12pm today saying I will come this afternoon and put a deposit down and it's sold.... Too slow junior. Shits me, but what can you do.
On 4/4/2018 at 7:11 AM, Leroy Peterson said:
You would think this issue would be noticed fairly quickly and then recalled or at worst, only affected a few months production. Surely ford are on top of it now...
They're still getting their heads around it
Sorry it's a day or two late
  • Like 1
Ended up cancelling my shitty ADSL at new rental place (NBN 6-9 months away but wouldn't be surprised if it actually is 1-2 years) bought a 200GB data sim from Optus for $70 month no contract
Before: 3 download / 1 upload mbps PING: 20ms-ISH
After: 25 download / 6 upload mbps PING: 30ms-ish
The only down side is 200GB limit vs unlimited data.. which is pointless anyway with such shit speeds.
tl;dr if you have shitty ADSL go get a Optus 4G sim and wack it in a 4G modem
Edited by UNR33L
  • Like 1
Well my house had NBN disconnected for 2 weeks while changing ISP. Good times.
NBN couldn't remotely do shit with the modem, so had to get a tech out. Then he'd done his work but something else happened (or slow response) and easter break hit. 3 days after holidays it was back on.
New router is shit though. Barely get signal on my phone to other side of house through like 3 walls. That's on 2.4Ghz because I disabled 5ghz, 5ghz supposed to be shorter range but will try it and see if signal improves.
Yeh 5ghz is a shorter range BUT more things use 2.4ghz so sometimes 5ghz is better to run on. Just try and test both out. Also pro tip: don't put modem near the microwave
Edited by UNR33L
I need a new modem as well, the one my republic give you is so shit.
not had to buy one for years as been living off the modem that optus Cable used as they kept sending me new ones every few years and worked a treat.
what are good and bad these days? had a good run with netgear back when I used to buy them.
Netgear still seem to be pretty standard / decent
Depends how crazy you want to go I guess, the Asus ones look good too
I use a Sophos XG105w at home
Edited by UNR33L
Was checking out Unit prices where I bought 3-4 years ago (Clayton) now that I don't get around the area anymore, soo surprising what similar places are going for now :O tempting as to sell would easily be around 200k in the pocket after deducting the remaining mortgage & selling costs.. Considering it to then use as a deposit for building / buying our own 'proper', "forever" house.. but still like that it's a nest egg, I guess we could use the equity of it to borrow on? is that a stupid idea?
It's what everyone else does, therefore it must be a good idea!
If your current rental is profitable, then you have no reason to sell. Different if you were older or something and wanted dream home.
Only if you’re willing to build a “Grand Design” worthy house Leigh.
Na, if you can afford it, and set on living in a place forever, go for it.
I know a few people who've done it and loved it. But the cars are thrashed, if you care about things being mickey mouse.
I did the Mario kart thing and that was the most fun I have had in a looooong time. It's great value.
  • Like 1
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
