While browsing for what Nismo parts were available for my Nismo R32 I found this solid shift unit and so I was wondering what opinions of it were:
http://www.kudosmotorsports.com/catalog/nismo-nismo-solid-shift-gear-lever-32839rn595-nissan-skyline-r32-gtr-gts4-r33-gtr-gts4-r34-25gt4-stagea-wgnc34-260rs-rsfour-p-1160.html
I currently have the interior stripped out of my R32 while it gets repainted so after that gets done it would be a good time to pop this thing in if it's worth the buy. I've never owned a car with a short shift kit before despite having numerous stick shift cars previously and the few times I've driven a car with a short shift kit it just seemed to make the shifts feel notchier so I'd like some opinions first before I decide to bother with this piece.
Thanks in advance for your replies.
https://www.sau.com.au/forums/topic/459065-thoughts-on-nismo-solid-shifter/
At that price it will be the 10% one - kudos have made a booboo on the description. The 25% one is $605 here;
http://www.kudosmotorsports.com/catalog/nismo-nismo-quick-shift-short-shift-kit-34110rn595-nissan-skyline-r32-gtr-gts4-r33-gtr-gts4-r34-25gt4-stagea-wgnc34-260rs-rsfour-p-1161.html
I have the 10% one and it just feels a little tighter than the stock shifter. I got it mainly because the boot was stuffed on my stock one and I was getting fumes in the cabin. Its fine, the sky wont fall in. but if you want a noticeably shorter shift you'll probably want the 25% one.
Will definitely feel notchier. Nissan boxes are bloody notchy anyway, so adding more is not awesome. The other aspect to consider is that quick shifters do encourage faster synchro wear. It may not be a major consideration, but it is there nonetheless.
Yeah, the R32 box is notchy already so if this just makes it worse I'll probably pass especially since I'm not planning on taking the car to the track except maybe once or twice just to see what it can do. Since they're so rare here in the US I'd rather risk one of my other cars at the track lol.
I wouldn't run one in my car. And i get everything nismo...
Is that because of the synchro wear issue, the feel, or both?
I saw that other listing and wasn't sure what the difference was for the higher price. Thanks for the clarification. I didn't consider that one though since 600 bucks seemed too much for a part that I didn't really need - I just was considering it since my R32 is a Nismo so of course I'm looking at all the Nismo parts available for the R32.
I've driven the 25% one, felt alot better than my stock one, much tighter and precise, made for some very quick gear changes...
Good to know it felt good to you but I don't think I can justify the 600 buck price at the moment for the 25% version.
  • 3 weeks later...
I've got the nismo 'solid shifter' on my car - the one with only 10%.
It doesn't feel much shorter in shift to me, but it does feel more 'solid' or more precise in the shift - I think this is due to the more solid bushing they use. The downside of this bushing I've found, is that it definitely transmits more gearbox noise into the cabin - something to be aware of.
Overall, I'm not sure I could recommend it - I'm glad I picked mine up as a cheap second-hander.
Noted. Thanks for the info. From what everyone is saying I think it's a pass for me on either one of the Nismo shift kits especially since my car will rarely see the track if ever.
I have the 10% one in my R34. I'm still building the car so I haven't driven it yet, however its installed and I would say it makes a huge difference. It really is almost solid, where as the rubber inside the shaft on the old one was so soft there was a huge amount of flex in it. Obviously this will come at the expense of NVH but I think it will be well worth it as the standard skyline boxes are not the most precise units.
I have an Attain solid shifter... MUCH better than the Nismo one IMO, better quality too.
I Had the Nismo one previously, and A/B ing them the Attain was much nicer to use.
And comes with a solid shift knob, and it's cheaper than the Nismo. With the spare change I changed the plastic bush for a GKTech brass one. I also have the upgraded spring kit int he box, and it feels pretty damn awesome. I also have a urethane gearbox mount.
http://www.rhdjapan.com/attain-solid-shifter-ecr33-rb25det.html
Just needs a close ratio gear set and Im golden. :rofl2:
  • Like 1
Did you notice much noise once you put the GKTech brass bush in? I have one sitting at home but dont know if i want to use it have the uprated springs and it makes the box feel a bit nicer
Yours may be a track car so the noise might not be an issue lol
it is a track car now, but it wasn't when I did it.
Didn't really notice any noise from the bush, but I had solid mounted cradle/solid diff bushes, urethane gearbox mount and Nismo engine mounts, so there was plenty of NVH coming from other areas.
I also don't really mind a little NVH though, so didnt bother me either way. Depends if the inside of your car is like a library or not. ;)
Thanks for the added input guys but unfortunately my car has decided to develop a case of "The Brokens" so the shifter issue is on the back burner until the engine gets sorted lol.
That gear knob looks like the one in the car i drove, i assumed it was a nismo short shifter, was zero noises from it and shifts were awesome like you describe , I had to learn how to drive again cause the shifts were so fast that i was out of sync with the accelerator and clutch so crunched it a few times :/
thanks for that link :thumbsup:
Edited by AngryRB
  • 4 weeks later...
I personally wouldn't run the "solid shifter" as it's basically a stock level cut shorter. the "quick shift" actually is fulcrum change so the shifter is stock height, but shorter throw. I run the quick shift and the quality is outstanding, same as stock, just shorter. The leverage does make it feel a bit more notchy but it's a good and direct feel to the shifts and they are nice and short. My wife loves it. I would certainly not pay 600 for it. find a used one.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
