While browsing for what Nismo parts were available for my Nismo R32 I found this solid shift unit and so I was wondering what opinions of it were:
http://www.kudosmotorsports.com/catalog/nismo-nismo-solid-shift-gear-lever-32839rn595-nissan-skyline-r32-gtr-gts4-r33-gtr-gts4-r34-25gt4-stagea-wgnc34-260rs-rsfour-p-1160.html
I currently have the interior stripped out of my R32 while it gets repainted so after that gets done it would be a good time to pop this thing in if it's worth the buy. I've never owned a car with a short shift kit before despite having numerous stick shift cars previously and the few times I've driven a car with a short shift kit it just seemed to make the shifts feel notchier so I'd like some opinions first before I decide to bother with this piece.
Thanks in advance for your replies.
https://www.sau.com.au/forums/topic/459065-thoughts-on-nismo-solid-shifter/
At that price it will be the 10% one - kudos have made a booboo on the description. The 25% one is $605 here;
http://www.kudosmotorsports.com/catalog/nismo-nismo-quick-shift-short-shift-kit-34110rn595-nissan-skyline-r32-gtr-gts4-r33-gtr-gts4-r34-25gt4-stagea-wgnc34-260rs-rsfour-p-1161.html
I have the 10% one and it just feels a little tighter than the stock shifter. I got it mainly because the boot was stuffed on my stock one and I was getting fumes in the cabin. Its fine, the sky wont fall in. but if you want a noticeably shorter shift you'll probably want the 25% one.
Will definitely feel notchier. Nissan boxes are bloody notchy anyway, so adding more is not awesome. The other aspect to consider is that quick shifters do encourage faster synchro wear. It may not be a major consideration, but it is there nonetheless.
Yeah, the R32 box is notchy already so if this just makes it worse I'll probably pass especially since I'm not planning on taking the car to the track except maybe once or twice just to see what it can do. Since they're so rare here in the US I'd rather risk one of my other cars at the track lol.
I wouldn't run one in my car. And i get everything nismo...
Is that because of the synchro wear issue, the feel, or both?
I saw that other listing and wasn't sure what the difference was for the higher price. Thanks for the clarification. I didn't consider that one though since 600 bucks seemed too much for a part that I didn't really need - I just was considering it since my R32 is a Nismo so of course I'm looking at all the Nismo parts available for the R32.
I've driven the 25% one, felt alot better than my stock one, much tighter and precise, made for some very quick gear changes...
Good to know it felt good to you but I don't think I can justify the 600 buck price at the moment for the 25% version.
  • 3 weeks later...
I've got the nismo 'solid shifter' on my car - the one with only 10%.
It doesn't feel much shorter in shift to me, but it does feel more 'solid' or more precise in the shift - I think this is due to the more solid bushing they use. The downside of this bushing I've found, is that it definitely transmits more gearbox noise into the cabin - something to be aware of.
Overall, I'm not sure I could recommend it - I'm glad I picked mine up as a cheap second-hander.
Noted. Thanks for the info. From what everyone is saying I think it's a pass for me on either one of the Nismo shift kits especially since my car will rarely see the track if ever.
I have the 10% one in my R34. I'm still building the car so I haven't driven it yet, however its installed and I would say it makes a huge difference. It really is almost solid, where as the rubber inside the shaft on the old one was so soft there was a huge amount of flex in it. Obviously this will come at the expense of NVH but I think it will be well worth it as the standard skyline boxes are not the most precise units.
I have an Attain solid shifter... MUCH better than the Nismo one IMO, better quality too.
I Had the Nismo one previously, and A/B ing them the Attain was much nicer to use.
And comes with a solid shift knob, and it's cheaper than the Nismo. With the spare change I changed the plastic bush for a GKTech brass one. I also have the upgraded spring kit int he box, and it feels pretty damn awesome. I also have a urethane gearbox mount.
http://www.rhdjapan.com/attain-solid-shifter-ecr33-rb25det.html
Just needs a close ratio gear set and Im golden. :rofl2:
  • Like 1
Did you notice much noise once you put the GKTech brass bush in? I have one sitting at home but dont know if i want to use it have the uprated springs and it makes the box feel a bit nicer
Yours may be a track car so the noise might not be an issue lol
it is a track car now, but it wasn't when I did it.
Didn't really notice any noise from the bush, but I had solid mounted cradle/solid diff bushes, urethane gearbox mount and Nismo engine mounts, so there was plenty of NVH coming from other areas.
I also don't really mind a little NVH though, so didnt bother me either way. Depends if the inside of your car is like a library or not. ;)
Thanks for the added input guys but unfortunately my car has decided to develop a case of "The Brokens" so the shifter issue is on the back burner until the engine gets sorted lol.
That gear knob looks like the one in the car i drove, i assumed it was a nismo short shifter, was zero noises from it and shifts were awesome like you describe , I had to learn how to drive again cause the shifts were so fast that i was out of sync with the accelerator and clutch so crunched it a few times :/
thanks for that link :thumbsup:
Edited by AngryRB
  • 4 weeks later...
I personally wouldn't run the "solid shifter" as it's basically a stock level cut shorter. the "quick shift" actually is fulcrum change so the shifter is stock height, but shorter throw. I run the quick shift and the quality is outstanding, same as stock, just shorter. The leverage does make it feel a bit more notchy but it's a good and direct feel to the shifts and they are nice and short. My wife loves it. I would certainly not pay 600 for it. find a used one.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
