I don't doubt the displacement argument but my engine is 2629cc at 87x73.7mm.. If I was going all out with a new N1 bock and stroker is 2738cc at 86
5x77.7mm thats 109cc difference for 7+ grand extra, you'd be nuts to take a virgin block straight to 87mm (assuming for a 2.6 refesh my crank and rods are fine, just new pistons) I would have though improving your VE% by 3 or 4 percent on the 87mm 2.6 with good head work would yeild similar results? If you're going all out, sure do both. But on an assembled 2.6 engine you'd see similar gains with just doing the head work. If I wanted solid grunt I'd be looking at over 3L for sure.
not sure if there still available but TOMEI had a 87.5 mm kit too which brought you out to full 2.8 which is an option.
besides nobody says you have to use a N1 block.
  • Like 1
In direct comp from my non built 26 to my built 26 my I gained power 300rpm earlier due to less rotating weight.
So the built 26 revs better and is a all round monster compared to when it not built.
and I didnt know that strokers didnt last as long. But I have heard of multiple built 26's going for 10 years (100,000km) before their standard rods failed (had tomei bolts and pistons).
I would be happy to get 10 years out of my engine.
price difference from my 2.6 to 2.8 is sweet FA!
1000 - 1500max
money well spent imo.
why spend money cleaning up the old crank which was in good nic + balancing etc, I now have a new 2.8 one.
I prefer the throaty note also.
You would of still got the 2.8 balanced though?
Together with being able to put a ton more boost into it.
No comparison to a stocker.
if I was to keep it 2.6 I'd go nitto and spin it to the moon.
I remember reading an article on a Fred Gibson interview and its interesting that he said that the RBs have an issue passed 8300 rpm. From memory he said due to the long crank, it didn't matter what they did, there was an inherent harmonics issue that would have detrimental effects on the bottom end if the rpm was kept above this point.
Don't know if he was using standard cranks or not, but I wonder if the issues still exist today with after market kits?
you can jam a shit load of boost into a stock engine. simon in wa is making over 500kw at the wheels on standard internals, is he doing it with 1 bar of boost? I don't think so
  • Like 1
Isnt that why RIPS and the like brace the block or fill it with something to stop the harmonic vibrations when things are taken above 8300rpm?
Suppose racing around a track when your RPM is that high for hours on end then I can understand the issue.
Not like a drag race where its 7-11 seconds worth depending on how deep your pockets go.
  • Like 1
Ripps specialize in RB30's.
The RB30 is known for that harmonics issue and ive discussed it with a few well known RB30 builders, the consensus is that its at over 8000 rpm at various points of the rpm scale at varying levels.
For example a engine may have a large one at 8200, a little one at 8500, another large one at 8800, a small one at 8950 etc.....
Point being is if you rev through it, its not a issue as your not sitting on it, you transition through it, you just dont want to be holding it at a particular high rpm where its at as it will want to tear its self apart.
  • Like 3
1 - Tomei stroker = $5,200 on nengun ATM. That includes crank, rods, rod bolts, rings and pistons.
2 - Machining and assembly, lets call that $3,000
3 - Head gasket = $300
4 - Water pump and oil pump = $1700 for both
5 - Head and cams. That could range from a service to a full blown $10,000 effort. For the sake of it lets go with $2,500.
6 - New timing belt = $150
7 - Bearings = $300
The rest of the stuff like sump baffles, turbo's doesnt really matter.
Items 2-7 you need regardless of what size engine you go with.
Now, Just say you have turned a bearing in your 26, crank is toast.
New crank (looked up a price on Ebay) = $1724
Pistons. Choose your poison. Lets go with CP = $1155
Rods. Say a manley H beam = $1280
Total $4159 for the rotating assembly. As opposed to $5,200 for a tomei stroker.
$13150 for a stroker
$12,109 for a 2.6 assuming new crank needed with the same above mentioned parts.
I havent inlcuded shipping in any of this. Either way you'd be paying it regardless.
These are VERY rough figures. I'm not going to sit here all night looking for the cheapest part or your brothers cousin can do a special price.
By the time you factor in injectors, clutch, fuel pumps, ECU, tune cost, exhaust, dumps, turbo's, intercooler, wheels, brakes, tyres and alllll te rest of the gear you need to "complete" a car, the difference is insignificant.
*Shudders* at cost because I'm tight. I also remember my OEM RB26 crank was under $1000 but that was trade price about 10 years ago so things may have changed.
Being around a lot of GTR's on the street and track over the last 12 or so years I can say this, a RB26 with a good set up will be better than and average set up RB28. A well set up RB28 is always going to be better than a RB26 (although they do tend to turn over a little sooner). In terms of cost, if you are building the motor it's probably worth the extra cash but if you have a healthy stock motor I'd be saving the $13k and getting the right modifications to make a well set up RB26.
Joey's RB26 is even more responsive than mine (by the dyno graph) and still makes awesome power. My RB26 has a little more top end potential but still has more power than you would need anywhere, check the footage below. This is a tight low speed track in a which stoker GTR owners would say would be a nightmare in a reasonable hp RB26, but even on sticky soft compound R-comps I have enough response to get boost anywhere I need it and enough power/torque to spin all 4 tyres through any corners at will.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
