Far out! Any updates from DBA?
Nope! Contacted them two weeks ago asking about any results from their internal investigations and to follow up the replacement rotors but have had radio silence. Will follow up again.
sooo they promised you a new set of rotors and now they've gone silent without sending you the rotors or even an explanation and it's been > 3 weeks?
they sure sound like a great company to deal with :unsure:
Had a mate recently have a problem with a dba t3 which we suspected had warped. He went to repco who made contact for him and dba sent a replacement rotor straight up - despite the purchase being 2 months past the warranty.
Interestingly, he was also running the 324mm rotor with the "dogbone" spacer on gts-t calipers
I've run T3 Clubs on my HSV. 365mm though.
4 track days (and 10k street kms) with 2 tonnes worth of car and plenty of HP so big stops always - No issues/cracks to report and I can tell you, my brakes get farken hot in the big tanker :)
  • 3 weeks later...
Spoke with the DBA rep and he said that they're still continuing their investigations with metallurgical testing being conducted now. It appears that it could be a one off incident with my rotors as they haven't seen anything like it before.
I also received the replacement set of rotors, which I have put up for sale as I'll be looking into a different braking package as I get faster around the track.
When I hear back on what their engineers say, I'll post it up here.
  • 4 years later...
Just get DBA4000 standard, ie no slots no cross drilled.
I always use them (car is 70% track 30% street), and all my racing mates too.
Have seen small fractures appear on heavily worn slotted ones however never seen any issues with the non slotted ones.
OEM is great, however the cooling characteristics of the DBA4000/5000 are greater due to the increased surface area in the cooling channels.
  • Like 1
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
