Have you checked your fuel filter since Pete?
How long you been running stock stuff for?
Are you sure the factory rubber hose has never been replaced on your 32?
So so many variables involved it's not really as simple as that ;)
Was only planning to change external rubber lines as they would have suffered the most exposed to the elements.
Yep all i want to know is how many meters of gates barricade to buy. Lol love this forum such entertainment!
From the Gates website:
" 85 percent Ethanol with 15 percent gasoline is not an aggressive fuel with respect to rubber compounds"
Just make sure you change your filter early and then again before much longer.
Factory lines are fine, if they have been replaced then go e85 hose just to be sure but the factory nissan stuff is fine.... mine sat for months on end and had been running e85 for years all on the oem hoses.
Probably done 100-150 E85 conversions with no issues on nissans with factory OEM hose
  • Like 1
I believe the cause of problems like the black goo with e85 was too high a fuel temperature, not stock rubber parts being deteriorated. I,e having an in-tank fuel pump and flowing a lot of fuel raises the temperature of the fuel to the point its almost boiling and during the spray pattern something burns of wrong and sticks to the injector. Out of tank pumps with cooler flowing fuel did not have this goo problem as much. I dont think it was ever a case of rubber melting.
Rust on the other hand...Has anyone opened up their engine after years of e85 and checked for rust?
How do you explain one injector only out of 6 having black gunk on it?
How does your explanation of hot fuel causing gunk to come out of suspension explain why the injector tips build up, and not the internal filter?
My fuel system has been hot, damn hot many times at the track, and on the dyno, I have never had an issue other than having to re-prime the fuel system to start. Never any rust either. I guess the Hydroscopic nature of the fuel doesn't matter at all seeing it's only in the tank for a month or two in my case, in fact it makes sure there is no water in the tank at all.
Not having a go, but all these misconceptions aren't helping unless you have some kind of proof, as evidence I have seen first hand rules them all out.
No offense taken scotty, I am never bothered about things like people "having a go" or not.
I don't claim to know any of this for a fact, just throwing out bits of information which may end up being helpful to some. I can only guess as to why one of the 6 injectors is doing it, maybe it had a slightly different spray pattern to begin with, or maybe it was just in the right place at the right time. Maybe in the same way you get vortexes within certain areas of a swimming pool, maybe you get the same within the fuel rail and the location matters, not just for streams but for temperature difference as well.
As for why the tip and not the filter, well the tip is where the action happens, and the fuel gets atomized, experiences a pressure change, temperature change, mixes with a new environment etc. Prior to that its all pretty uniform stuff, kind of like how a Volcano only starts to smoke and clog up at the tip and not as its making its way through the earth.
The only reason I brought this up is I was personally curious as to what the reason was injectors were dying out with e85, which happened to me on a number of times, and there is 100s of theories and the exact number of counter theories to those theories, but what I came across that was most striking was that the people, all other factors identical, people with inline fuel pumps were having the issue much more than than people with external fuel pumps.
All the components and materials were identical, the only variable changed was fuel temperature at the injector tip, which was always higher with the in take pumps, and it coincided more with the goo. I haven't confirmed any of this it just made the most sense to me so I thought I would share it.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
