Now the car drives awesome. Traction is an issue with the shitty falken 265's that are on at the moment. I am contemplating doing an e85 flex tune. Trent reckons another 40 odd rwkw is achievable. All I have to do is get a bigger fuel pump and rewire it with a relay, add a flex sensor and tune for the e85. Some days I really feel like doing it, other days not so much. What are peoples opinions on flex fuel?
Melbourne weather has been shit so far today. So waxing with collonite is on the backburner but I managed to sort my traction issues this morning. Got a set of Achilles 123s tyres fitted. 265/35/18 all round. I know there's much better tyres around but @ $150 fitted each I couldn't go past them. If anyone wants any, import monster has a limited supply at this price. First impression driving home in monsoon like weather is that they're pretty good in the wet. No unwanted wheelspin unlike the falkens that came off. I was 4 wheel drifting around corners this morning without trying to. I will update about the performance of the 123s as I drive on them.
^Thanks dude. Wideband sensor is on the front pipe just in front of the cat, I'm still running the OEM one in the factory position and that gets used while the wideband warms up or fails. I'm not running an air sensor ATM which apparently is a big no no but the AFR seems to be fine whether its cold or hot but I will be installing 1 soon just in case. Im thinking of putting it in the crossover pipe just b4 the throttle body.
Bit of an update, Dropped the front end about an inch or so yesterday. Looks heaps better, although another inch lower would be great. Made it up the driveway at work ok, just got to see if I can get out this afternoon without destroying my front bar. Fingers crossed. If all goes well I may try lowering it a touch more and then adjust the rear to suit. Here's a couple of crappy pics. The Achilles 123s tyres seem to be doing very well in wet or dry. Really have to punch it hard to break traction in the dry. Only negative is they are noisy farkers. The collinite wax is doing it's job awesomely as well, the water is beading off the paint like water off a ducks back and the paint still looks clean after the water has dried :smile:
Managed to crawl out of the driveway at work with only a minor scrape. I'll try and refine my exit strategy tomorrow and hopefully I can make it out with out scraping so then I can lower the front some moreB)
Talk to a good tuner and see what he says about afr gauges...
I've heard and seen nothing but crap from them, they are not even close to the same readings on a dyno unless you get a very high end unit from haltech for example...
The $260 odd dollar ones are not accurate and I've seen a few cars go bang because of this, owners believing the gauge over the dyno.
Josh
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
