Hey Bill,
I'm curious as in how do you mount the Adaptronic ECU?
Is it mounted where the stock ecu resides in?
Hey Grant, yeah it lives in the same location as the factory ecu. I just had to move a couple of relays out of the way and drilled one hole to mount it where I wanted it. Plastic foot well cover fits over it and hides it nicely. I'll take a pic when I get a chance and put it up.
Hey Grant. Here's the pics. I used to have it the other way so the loom plugged in from the right but it didn't leave much room for the USB and wideband input, I ended up snapping the USB port off. Adaptronic was very helpful. This way gives plenty of room above for those inputs and it fits nice and neat, the cover also fits back on perfectly. I did also relocate 2 relays. Im not sure if the GTR is any different but I guess you're going to find out pretty soon. bf0b7a751511ce4c812c408582c7417e.jpg7af54f6f57fa41d2e78baf2b3d5ba078.jpge49da880cdb1f1daf82c1cd50492fbc4.jpg
  • Like 1
Thanks again Bill.
I've sussed out another solution last night.
Take apart brackets from stock ECU and then I compared it to both Power FC I have and stock ECU with Adaptronic, width is the same and it mounts like stock ECU do.
The plan is to velcro strip to hold it together, see how I go.
Thanks again.
I shaved off the tabs and used the OEM brackets and drilled into it.. works a treat however the rear USB plug sits against the firewall padding.. but using a 90 degree USB plug work "ok".
I too snapped off my USB plug, but I managed to solder it back and then applied 1000000000x coats of super glue to it LOL
Super glue ftw. In my case I burnt an led while trying to solder the USB back on. Oops. The guys at adaptronic came to my rescue. Absolute legends.
oooots!
need Plazmaman cooler [emoji4]
That would be nice but its probably worth more than my car, lol. AWD would be nice too, that ain't gonna happen either. Can't afford any more mods, too busy pumping e85 in the fuel tank and helping United make massive ethanol profits[emoji3]
  • Like 1
Probably could get a generic 76mm pro series core at a good price :)
Holla if you're ever interested.. also can get good prices on DBA rotors, Hel lines and especially Intima Pads!
Probably could get a generic 76mm pro series core at a good price [emoji4]
Will deff keep you in mind[emoji106]
New tyres fitted this morning. Buy 3 get 1 free. Fresh 2016 production 265/35/18 AD08R. Thank you Mr Yokohama and Mr Bob Jane for the excellent pricing. Definitely an improvement over the Achilles 123S which weren't bad but just did not last.
5ad634137e67d3ac5e5748a727a270b3.jpg3bc9baccfeb313bec573f8bb60ceb336.jpgfc099c1922eee1e2f496ab54e38783ae.jpg
Looks awesome! Do you drive this daily?
Yep, driven just about every day and at every possible opportunity. I thought about putting a baby seat in the back so I could drive it even more but stopped short on that idea[emoji3] . lol
shit got real when you daily some AD08s lol
At $263 each fitted. I can afford to daily them. Got to try to get the power to the ground somehow. For that price, I'd choose ad08's every time. Sadly it is very rare, I think the guys at Bob Jane may have even f#*ked up with that price but I sure as hell wasn't going to question it. I couldn't say yes any quicker actually[emoji12]
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
